Bad Rings?
Old 03-04-2009, 10:44 PM
TAEnvy's Avatar
Default Bad Rings?
How would you know if youve ruined the piston rings in your motor.
My car had some bad 02s and ran exxecively rich for a while. I mean bad to.
Got some new ones and ran great for a while, now its starting to get really rich again, and getting bad gas mileage again.
The other day I hopped on the highway and hit it in 2nd and a buddy of mine said I had a puff of blue smoke out of the exhuast. Never had this before so It got me a little worried.
How would I tell If I ruined some rings?
Car seems to run great outside of some idling issues when shes cold (expected with a mail order tune on a big cam). Also when its cold and you hop in and try and take off right away, it will miss and hesitate for a few seconds. Pretty much the first time you get the rpms up though its fine.
Old 03-04-2009, 10:48 PM
ss.slp.ls1's Avatar
I'd perform a compression and leakdown test.
iceman15's Avatar
i think blue tinted smoke means that oil is getting into the combustion which means that your valve seals might be going bad. someone should chime in and clarify that
Old 03-04-2009, 10:52 PM
michaelz28lt1's Avatar
Yep do a compression test
Old 03-04-2009, 10:54 PM
TAEnvy's Avatar
I thought I might have tore a valve seal when doing the cam swap, so that was my intial guess and figured Id just tear into it as soon as I got the blazer running, then after I thought about how rich it was running for a while (unburnt gas out the exhaust) I started to worry about the rings.
And it just started running rich again out of nowhere. I really need to get it dynotuned. \
Luckily its about to be back up on jackstands and not seeing DD duty anymore.
Old 03-04-2009, 10:57 PM
iceman15's Avatar
Yea you might a few problems going on there. Do a compression test for sure as well as scan the car and see if you are throwing any codes.
Old 03-04-2009, 11:07 PM
TAEnvy's Avatar
No codes being thrown, I have a solus at the shop, already scanned it.
Gonna compression test it as soon as I can.
Old 03-05-2009, 07:18 AM
TAEnvy's Avatar
With the cam Im gonna have a different dynamic compression than stock. So theres no telling what psi reading I should get on a compression test, right?
I guess Ill just be testing for how the cylinders compare to each other
Old 03-05-2009, 11:17 AM
ss.slp.ls1's Avatar
Yeah, consistency is the important thing.
Quick Reply: Bad Rings?
