i need new heads and cam
Old 03-16-2009, 08:07 PM
johnwrench's Avatar
Default i need new heads and cam
hi everyone i sold my heads off my car and need new ones. lt1 stock ci. every bolton you can get.
i run a 10.79 on my old heads and lt4 hot cam and i would like to get in the
9s with new setup.
can everyone give me some ideas
Old 03-16-2009, 08:10 PM
ss.slp.ls1's Avatar
9s with new setup.
Call or look up Advanced Induction, they can get you in the 9's.
http://www.advancedinduction.com/
Old 03-16-2009, 08:11 PM
kinglt-1's Avatar
beat me too it lol, agreed!
Old 03-16-2009, 08:15 PM
z28rob18's Avatar
+3 lol
Old 03-16-2009, 08:20 PM
RamAir95TA's Avatar
What heads were you using before?
Old 03-16-2009, 08:21 PM
johnwrench's Avatar
i called Advanced Induction and elliotts portwork thay said to get my heads back
Old 03-16-2009, 08:22 PM
johnwrench's Avatar
milled stock
Old 03-16-2009, 08:23 PM
ss.slp.ls1's Avatar
What's your budget?
If money was no option, I imagine it would be hard to beat ported AFR's and a custom grind cam.
Don't know what your race weight it, but weight reduction always helps.
What gear, stall (if auto), and tires are you running?
What size shot were you using with that 10.79 run?
z28rob18's Avatar
buy a set of trickflows off of AI
Old 03-16-2009, 08:28 PM
ss.slp.ls1's Avatar
milled stock
Huh? Lloyd and Ai told you to get your milled (non-ported?) stock heads back? Why?
If you had milled stock heads, LT4 hot cam, and spray and you ran a 10.79, ported stockers, beefy cam, and upped shot will definitely drop your ET by .79 (assuming you can keep traction).
Old 03-16-2009, 08:29 PM
RamAir95TA's Avatar
IMO, for us to help you, you need to pick up the grammar a bit.
Old 03-16-2009, 08:32 PM
johnwrench's Avatar
i have about $3500. race weight is 3200. vig 2800 stall .gear are stock323. it was a 200 shot that got me 10s
Old 03-16-2009, 08:37 PM
RamAir95TA's Avatar
Here's what you do.
$2000 AI heads/cam.
$1500 for a new converter (at least 3500) and new gears (at least 3.73s).
That, plus a 200 shot, all bolt-ons, sticky tires, headers, etc., could potentially put you deep into the 10s.
Old 03-16-2009, 08:46 PM
johnwrench's Avatar
Lloyd and Ai told me that aftermarket heads are hard to get the compression ratio back up without a new lower end.
Old 03-16-2009, 08:47 PM
Elliott's94Z's Avatar
LMAO
AI would prob be your best bet if you are shooting for low 10's or 9's
Old 03-16-2009, 08:48 PM
RamAir95TA's Avatar
All the more reason to go with AI/LE's ported stock castings!
Old 03-16-2009, 09:03 PM
TABBED 5.3's Avatar
any times with that old combo on motor?
Old 03-16-2009, 09:24 PM
johnwrench's Avatar
na it ran a 12.4something
Old 03-17-2009, 05:41 AM
z28rob18's Avatar
Here's what you do.
$2000 AI heads/cam.
problem is though without a core to send them i think its a $600 charge. if you didnt need a stall id say go with a set of trickflows but u said youd have compression problems. of course you can always find stock heads to send in for less then $600
Old 03-17-2009, 08:40 AM
Advanced Induction's Avatar
Smile
If you have a stock short block, you do not have many options. On average, we see 100-130hp gains with our 200cc CNC'd GM casting, a daily drivable HR, and 11:1 compression. Naturally, that assumes proper installation, adjustment, and tuning. That kind of gain coupled with the highest quality machine work, perfectly consistent ports (read: potential), and quality components represent a value that is difficult to compete with.
Your car sounds like this gentleman's setup with a little more n2o. His ET was reduced by over a second swapping to our complete top-end. Keep in mind, any time you add large amounts of power to a finely adjusted setup you will usually need to do some re-adjusting before you run at full potential.
https://ls1tech.com/forums/lt1-lt4-m...na-9s-n2o.html
If you decide to have your stock heads cut, we would advise you to seek out an un-machined set. The deck serves as a reference plane for machining. If your castings were milled a minor amount then they would likely be fine. In any case, if you send them in, please write on them in sharpie what has been done to them previously.
If you have more to spend, our CNC'd packages w/ the new 21deg TFS casting would be a nice step up. It does not appear that we will have castings to machine until end of April however.
Thanks for the interest, guys.
Quick Reply: i need new heads and cam
