95 z28,what kind of oil goes in the rear end
Old 03-19-2009, 10:37 PM
rspears9's Avatar
Default 95 z28,what kind of oil goes in the rear end
im going to change the oil in my 95 z28 rear end,what kind and weight does it take.
Old 03-19-2009, 10:44 PM
LT1
LT1's Avatar
80-90W gear oil with limited slip additive.
Additive GM part number 1052358
Old 03-20-2009, 08:34 AM
rspears9's Avatar
Default gear oil
how much does it hold.or how many ounces.quarts
Old 03-20-2009, 09:48 AM
multmigs's Avatar
Or you could you something better like REDLINE NS which is designed for clutch style Posi Rears.... It won't be as quite as stock but you will notice a different in hookup...
Old 03-20-2009, 11:23 AM
CAMJAG's Avatar
Is the Red Line NS a non synthetic?
Old 03-20-2009, 08:02 PM
multmigs's Avatar
Yes it is, I think all the redline gear oil is?? You'll need to quart size bottles but the second won't be empty.. Last time I did this I used one bottle of the NS and one regular no other additives, the car launches!!!
Old 03-20-2009, 08:05 PM
RamAir95TA's Avatar
Just under 2 quarts. Don't forget the GM LSA!
Old 03-22-2009, 06:57 PM
integraxtc's Avatar
Mine is a 96, T/A how do you know if you have a limited slip?
I don't think mine does. I just replaced it w/ 80w-90 conventional.
Old 03-22-2009, 07:03 PM
RamAir95TA's Avatar
All V8 cars came with LSD.
Old 03-22-2009, 07:24 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
How much limited slip additive is called for? I changed my diff fluid, but didn't use any additive. My car is on jack stands, and isn't being driven.
RamAir95TA's Avatar
You need to use one full bottle of the GM stuff.
Quick Reply: 95 z28,what kind of oil goes in the rear end
