need some cam help.
need some cam help.
Ok so I'm rebuilding my motor and my question is what would be a good cam for a 355 with stock heads. I want more power but it's my daily so I need some reliability. im thinking about the cc503 but im unsure right now.
I use to DD with a cc503 and it was great, very reliable and comfortable. That cam works real nice with stock heads too. I wouldnt go any larger if I were you for a DD and make sure if your an auto that you get the proper stall to match whatever cam you decide on otherwise DDing will become a nightmare.
http://www.converter.cc/
I had good luck with a 230/236 .544/.55 112lsa grind when I had my 355 in before I swapped it out for my 383. I used a 3200 stall and that setup was pretty streetable. I actually still have the cam if your interested. http://www.cardomain.com/id/Chevyguy358
Although my heads did have some work done to them, it was mostly just alil minor work
