air pump removal
u will require intake manifold A.I.R block off plates and Exhaust manifold block off plugs, and not to forget to block the hole in the air intake elbow, u can use a vacum plug for that. oh yes, i also believe u will require a tune,,then just simply unplug the pump and remove along with all the hoses
Just remove everything. The piping can only be removed if you destroy it. If you have a 93-95, use a M22 plug for the exhaust manifolds. 96-97 cars use an M18 plug. Plug the hole in the intake elbow. If you have an OBDI car, as long as there is a good fuse in the system it shouldn't set an SES light (although there have been reports of an SES setting in this scenario). You can have the SES tuned out, though. OBDII cars will set an SES - same deal.
It's fairly simple, but we kind of need to know what year LT1.
my cars a 96 ss and i just got the car tuned i just need to take all the emission stuff off the car now. what do u mean about the m18 plug and that the size or the part number of it
Mines a 93, but I removed all the stuff and left the stuff on the back of the intake lol I just capped off the AIR line back there as to not be a massive vacuum leak, and now it and the EGR are my "block offs"
If by chance when you unplug the EGR solenoid, and it throws an SES right away like in my case (apparently I didn't tune it out enough), all I did was cap off the solenoid vacuum lines and then leave it plugged in. Doesn't do (actuate) anything anymore, but keeps the SES from tripping. I saw no AIR triggers in my primitive 93's tune, but with the fuse IN and just unplugged AIR pump (which RamAir mentioned), didn't trip anything for me.
