Cam bearing help needed.
I pulled my cam out last night and noticed that there are some rough spots on my front cam bearing at 3 and 9 o'clock.
Does the bearing need to be replaced? the engine has 130K+
If it does, what tools are needed
The oiling holes should be 90* apart, so its not them, how deep are the rough spots?
If you can see/feel anything you mise well replace it, the front bearing is prolly the only one you can get out with the engine in the car. You will need a cam bearing driving tool, but you will need to find a way to get the old bearing out, but so it is driven out the front, not pushed back (then you couldn't get it out).
I carefully tapped out all of mine with a metal pipe (may I stress carefully), then if you did knock it toward the block you could always crush the bearing so you could pull it back out of the front. Just tie a string or something to it so you don't lose it lol.
You can tap it out and if you push it back you can crush it to get it in an oval shape to get it back through the hole. Its up to you though, its your car and if you're uncomfortable doing it, don't if it gets messed up you could be stuck into pulling the engine out.
Any pics, maybe we can see how bad the wear is?
i will try and take some pictures tonight.
