LT-1Vette wants to start after shut off HELP
Old 05-12-2009, 05:08 PM
1gt2nv's Avatar
Default LT-1Vette wants to start after shut off HELP
My mom has a 96 LT-1 Vette. When she turns the car off, it wants to start itself. The car trys to start untill you put the key in and start it. Then it will turn off. What could this be? Starter?
Old 05-12-2009, 05:15 PM
93cz28's Avatar
you probably have a short thats giving the starter power.My guess is one of the ignition wires is shorting it, if it does it while the key is in.check under the car and see if there are any loose or stripped wires touching each other or the starter.
Old 05-12-2009, 05:17 PM
litch2004's Avatar
its called dieseling but not sure what could cause it
Old 05-12-2009, 05:27 PM
ss.slp.ls1's Avatar
From his post you can't tell if it's dieseling or cranking.
OP, I would do what the second poster mentioned.
Old 05-12-2009, 05:55 PM
93cz28's Avatar
if it was dieseling it would keep running even after the car was off because it would still be burning fuel...but without spark.a hot spot in the cylinder would be causing the fuel to ignite, and then the engine would shut off. OP we need more info on exactly what it does tho....
Old 05-13-2009, 03:48 PM
1gt2nv's Avatar
It's not dieseling. I know what that sounds like. It sounds like the car is trying to turn over and over and over.. Like it wants to start.
Old 05-13-2009, 04:42 PM
Vettestir's Avatar
I have a 96 Vette and the same thing just happen to me a month ago. It turn out to be the starter was not disengaging the flywheel and kept running. It got so bad I had to tap the starter with a hammer to knock it loose. I put a new starter in and it's fixed.
Old 05-13-2009, 05:24 PM
RamAir95TA's Avatar
Check the purple wire connected to the starter solenoid, and the opposing power wire. Sounds like there's a short somewhere.
Old 05-20-2009, 06:20 PM
ss.slp.ls1's Avatar
Oddly enough my car started doing this yesterday. I went to start the car and the starter is continuing to try to start the car even after the car fires up. It does if for like 10-15 seconds until I blip the throttle a few times and it stops. I sounds like the starter is not fully disengaging the flywheel. I was thinking about adding a shim to the starter to see if that fixes it.
Quick Reply: LT-1Vette wants to start after shut off HELP
