Whats everyone doing with O2 sensors after Long Tubes?
Old 05-13-2009, 07:58 PM
Black94Z28's Avatar
Default Whats everyone doing with O2 sensors after Long Tubes?
I got some Hooker headers just installed on my 94. They dont have the O2 sensor holes in them. I plan on running some collector extensions to bullet mufflers to turn downs. Should I just drill and weld a nut onto the collector extension. If I do that what should I do about the wiring for the sensors? Can I buy longer ones or do I just have to cut and rewire them?
Old 05-13-2009, 08:02 PM
RamAir95TA's Avatar
You should buy O2 bungs and have them welded in.
Use O2 sensor extensions instead of cutting/crimping.
ss.slp.ls1's Avatar
You need to get a pair of o2 sensor bungs and weld them in at the collectors. Do some research for the optimal location. I'd use new AC Delco o2 sensors and some Caspers Electronics o2 extensions.
Old 05-14-2009, 10:47 AM
Green3spd's Avatar
I did that.. Im just goin end up buying extenstions...
Old 05-14-2009, 09:27 PM
Black94Z28's Avatar
where can i buy them at?
Old 05-15-2009, 01:17 AM
itSSlowZ28's Avatar
i got mine from thunder racing. plug and play, just make sure you zip-tie any excess away from the header
Old 05-15-2009, 09:46 AM
96SCTA's Avatar
I cut / then solderd my own extenishons when i use to use o2 sensors. Takes maybe 20 minutes to make your own and saves some cash.
Old 05-15-2009, 10:59 AM
sweetbmxrider's Avatar
ebay $40 for a pair
Old 06-02-2009, 05:59 PM
redfbird99's Avatar
what size O2 sensor extensions did you guys end up having to go with? I just bought some longtubes and I see they are available in 12 inch and 24 inch extensions, I just want to make sure I buy the right ones!
Old 06-02-2009, 06:03 PM
Z28Camaro30Ann's Avatar
I used 24". I figured if they are too short I am screwed and need to buy more...if they are too long, you always have zip-ties and those are A LOT cheaper than another extension...if you have excess, tie it off.
Old 06-02-2009, 06:05 PM
Also back to the OP...you need those front 2 O2 sensors so get some bungs and have them installed on your headers. As for the rear 2 O2 sensors, don't tune them out! Get O2 Sims and stick those on there...The computer likes that better than tuning them out...
Old 06-02-2009, 06:16 PM
baylove's Avatar
DO NOT CUT YOUR WIRES do it the neat way get some extensions plug them in and forget about it i purchased 24's and zip tied the slack out of the wires they work great
http://www.lmperformance.com/3112/2.html
ebay
http://cgi.ebay.com/ebaymotors/LT1-G...mZ360133992349
Old 06-02-2009, 06:21 PM
ss.slp.ls1's Avatar
Old 06-02-2009, 06:24 PM
lol, just making sure he doesn't try and completely get rid of em lol. They control that Air/Fuel ratio and getting rid would be bad juju...I was just emphasizing that lol
Old 06-02-2009, 06:28 PM
ss.slp.ls1's Avatar
Negative, the rear o2's have no affect on A/F ratio, they only monitor the efficiency of the catalytic converters.
Old 06-02-2009, 06:52 PM
redfbird99's Avatar
has anyone tried 12 inch extensions? It'd be nice to have very little slack if possible, i definately don't want them too short though!!
Old 06-02-2009, 06:59 PM
ss.slp.ls1's Avatar
I got a pair of 24" ext because, as stated, it's easy to ziptie the slack and still look clean.
Old 06-02-2009, 07:40 PM
nik1703's Avatar
Good! so im only replacing my front o2 then! lol
Old 06-02-2009, 07:54 PM
ss.slp.ls1's Avatar
OBD1 cars only have 2 o2's. OBD2 cars have 4 o2's.
Old 06-03-2009, 12:59 PM
kinglt-1's Avatar
The rear o2's do not affect fueling on our cars. Only newer cars from 2005+ w/ can obd2 deal with that issue. They can alter fuel trims a bit if they detect issues with cats efficiency. Again this does not apply to LT1 cars...
Quick Reply: Whats everyone doing with O2 sensors after Long Tubes?
