Heads questions
Old 05-19-2009, 12:25 PM
305 h.o.'s Avatar
Default Heads questions
Thinking about getting another set of Lt1 heads and having them worked. 3 angle valve job, shaved 20 thousands and ported. How much hp would this pick up and would it be ok if I shaved the heads as far as getting good valve clearence.
Old 05-19-2009, 12:33 PM
ss.slp.ls1's Avatar
What I would do is contact Advanced Induction and pick up a set of ported stock heads from them. They should answer all of your questions.
Puck's Avatar
Valve clearance will most likely not be an issue on most builds, but "ported" is the most vague description ever. It can be anywhere from a huge gain to a loss of power depending on who does it.
Old 05-19-2009, 12:38 PM
305 h.o.'s Avatar
I thought porting was the shiznet. Ow well.......
Old 05-19-2009, 12:39 PM
305 h.o.'s Avatar
Im not trying to put a crap load of money into some heads, I just want somthing above and flows better than stock.
Old 05-19-2009, 12:40 PM
ss.slp.ls1's Avatar
It is, he's saying it all depends on the quality of portwork, aka, who does the porting. If you took a die grinder with no experience and hogged out all of the ports, you'd likely be left with 20+ lb paper weights. But if you take your stock heads to an experienced head porter, the gains will be impressive.
Old 05-19-2009, 12:41 PM
ss.slp.ls1's Avatar
Well then a simple 3 angle valve job and a slight mill are all you want.
Old 05-19-2009, 12:44 PM
305 h.o.'s Avatar
The place that I want to take them to specialize in heads.
Old 05-19-2009, 12:49 PM
ss.slp.ls1's Avatar
Well then hopefully their portwork is of good quality.
Old 05-19-2009, 03:14 PM
RamAir95TA's Avatar
Specifically LT1 castings?
Old 05-19-2009, 03:41 PM
305 h.o.'s Avatar
yea...
Old 05-19-2009, 06:25 PM
fuzzyjk's Avatar
OP asked what type of power increase, I am interested in the answer too.
Old 05-19-2009, 07:13 PM
derekderek's Avatar
I was wondering how much power just off shaving them down and raising compression. And how much can you have them before you have to worry about valve clearance. I know it will depend on the size of cam but lets just say stock cam.
Old 05-19-2009, 08:31 PM
My95Z's Avatar
Every 1 point in static CR increase is roughly 3% power increase IIRC, not huge gains and pretty much guarentees you'll need premium fuel.
As for power increase from porting, again it all depends on who does them and what they do to the heads. Power gains can be minimal from just "cleaning up" the castings to extreme at AI or LE quality.
Old 05-19-2009, 09:30 PM
fuzzyjk's Avatar
There is no porting, just shaving the heeds 20 and a 3 angle valve job. Lets assume a stock and a baby cam 224/230. Will the heads gain you anything on either cam?
Old 05-19-2009, 09:33 PM
RamAir95TA's Avatar
No one can tell you a specific number. There is no magical horsepower number that is just pulled out of a hat or a special equation to determine such. The correct answer is "some."
Sheesh. When will everyone understand that it is the sum of the parts that make power, not individual components?
Old 05-19-2009, 09:43 PM
fuzzyjk's Avatar
OK point taken, but this is why I ask...I can get my current heads shaved, 3 angle valve job and assembled for 400.00 plus 250.00 in parts locally or I can send them to LE for there budget head deal for 800.00 plus shipping ($900 all in). Just tring to figure if it is worth the down time and $250 to ship them to LE? If the HP is near the same I will stay local. Oh ya 224/230 cam with cold air, and LT headers.
Old 05-19-2009, 09:55 PM
blake110106's Avatar
damn who are you shipping through? $250 is outrageous. Im in Ky and I just shipped my stockers to Fl for $23 UPS ground.
IMO i wouldnt do a mild port job on a head cause then it would just make you want more. That would lead to spending more money than just sending your heads to lloyd to do the LE2 heads. 1350 shipped for heads and 1650 shipped for H/C is one hell of a deal.
Old 05-20-2009, 07:50 AM
fuzzyjk's Avatar
Shiping is about $50, the difference in price is the head work itself.
Old 05-20-2009, 10:53 AM
ss.slp.ls1's Avatar
If you have the money to get them ported from LE, do it.
Quick Reply: Heads questions
