1.6 rr
Old 05-21-2009, 01:51 PM
deviladvocate's Avatar
Default 1.6 rr
I was a dumbass didnt do research and bought SA RR's when I need NSA.
My question is, is there any difference between the Gen1 RR's and the LT's. or are they both compatible with each other. I was looking on summit racing and i could not find a decent set of fairly inexpensive 1.6 NSA RR's. I was going to pick up the summit brand, however they only have the 1.6 nsa for the gen 1 motor.
BTW if anyones interested in a set of 1.6 sa rr's pm me.
Old 05-21-2009, 01:53 PM
ss.slp.ls1's Avatar
I believe they are identical.
I usually recommend getting Comp Pro Mags NSA 1.6 ratio for a 7/16" stud.
Old 05-21-2009, 02:20 PM
whats the difference between 3/8" and 7/16" studs. I have already purchased the 3/8" and dont want to return them unless there is a big difference with the two of em.
Old 05-21-2009, 02:30 PM
96lt1m6's Avatar
It really depends on what you are doing with the car. If you are mild performance the 3/8 studs will be just fine. If you are more of a performance type of driver you will want to upgrade to NSA rr,hardened pushrods and guide plates for added stability.
7/16 studs are much thicker and provide a stiffer area for deflection whereas the 3/8 will flex at higher RPM. If i were in your situation i would sell the SA rockers and get the 7/16 set up strength in the valvetrain is something you should always have.
Old 05-21-2009, 02:48 PM
Yeah I know a strong valvtrain can mean the difference power wise.
I already have chromoly pushrods, guideplates, 3/8 top - 7/16 bottom studs.
Studs
I just need to get the nsa 1.6 rr's cuz I was an idiot and bought the wrong ones lol.
Do you think this would be a stable top end setup for a street car with a 355 bottom and AI heads and cam?
Old 05-21-2009, 02:56 PM
96lt1m6's Avatar
it will be as stable as 3/8 stud will allow. i would NEVER entertain the thought of a good cam and SA rockers though
Old 05-21-2009, 04:17 PM
yeah it seems the more i read up on sa rockers, the more i sound like an idiot lol...
oh well time to sell some New parts! =P
7/16 studs, 1.6 nsa rr here I come. how do you guys suggest i measure pushrod length.
Old 05-21-2009, 04:26 PM
ss.slp.ls1's Avatar
The right way, lol. You need an adj pushrod and either a solid lifter or a test spring. Do a search here or on and you should be able to find a nice write up.
Here's some:
http://www.circletrack.com/techartic...gth/index.html
http://www.carcraft.com/techarticles...gth/index.html
Old 05-21-2009, 05:49 PM
litch2004's Avatar
here is a write-up:
Quick Reply: 1.6 rr
