Opti spark problem need help
Old 05-30-2009, 06:20 PM
94firehawk's Avatar
Default Opti spark problem need help
I just put a new opti in my car and it turns over but wont start anybody know what it could be??
Old 05-30-2009, 07:12 PM
latindragons's Avatar
Could be a vast number of problems. Why did you replace the opti to begin with? Was it cranking and not starting to begin with also? Could be that you're not having enough or any fuel. Doesn't always need to be the opti on our cars. Fuel pumps are known to go bad. Any other symptoms? Can you hear the pump priming with the key in the ON position?
Old 05-30-2009, 07:20 PM
94firehawk's Avatar
the fuel pump works but i replaced cause it caught fire but it worked fine. the opti i put in it i had in the garage for 4 years
Old 05-30-2009, 07:36 PM
Hmm...Could be something as simple as maybe you accidentally put the rotor in the opposite direction. Or the wiring going to the opti was damaged during the fire. Did you happen to change the spark plug wires, as well? Or your coil was damaged during the fire also. Might want to try to pull the fuel pump fuse and check to see if your getting any spark, at all.
Sorry I'm not really giving you a solid answer man. It just could be so many possibilities. I'm sure someone else will chime in here soon.
Old 05-30-2009, 08:06 PM
koolaid_kid's Avatar
Put an inductive timing light on it. It will show you whether or not it is getting spark.
AFA the fuel pump, did you check pressure with a gauge? It does not have to be running, just keyon.
Old 05-30-2009, 08:26 PM
94firehawk's Avatar
i might put the old opti back on it to see if it cranks the opti could just be bad or could it be the crank sensor
Old 05-30-2009, 08:54 PM
shbox's Avatar
94s don't have a crank sensor. Even if it did, an LT1 does not need it to run.
Old 05-30-2009, 09:05 PM
1994formulalt1's Avatar
you might have the thing out of timing i think i did it when i put my opti in my 94 i had to take it all apart and flip the rotor around and it worked
Old 05-31-2009, 06:28 PM
94firehawk's Avatar
well my car is a 96 it does have a crank sensor. also i put my old opti on it and it still just turned over and didnt start put it was working fine before i just replaced it cause it melted a little bit.
