power stearing reservoir relocation
has anyone tried moving their factory reservoir here? I had a wild hair one night and tried it out just to see if it would fit.
Now the bracket that is there WOULD NOT be the final piece. As you can see there are a few different holes in the plate from having to try different things to clear the spark plug wires. I would be making a new one using the correct holes.
Looking at it right now with nothing really there it looks good. The is also including the fuel line relocation and the abs delete. I just like opening a hood and only seeing an engine.
Your going to have nothing but problems. Your resivoir needs to be above the rest of the power steering system. If not, you will have air in the system. And every time you open the cap to fill it, the remaining fluid in the system will drain out. You must remount the resivoir above the rest of the system.
why would it drain out? And why would i be opening it all the time to fill it? I have never had a car that i have had to fill the power steering reservoir more than the first time i fill it. that is unless i am draining it to put new fluids in.
But this is the reason why i am asking. It is higher than the power steering just not the pump. It is slightly lower than the pump.
I like the idea, it is just that it seems a bit out of place like others were saying. Maybe turning it 90* degrees or go to the junkyard to look for a small square/rectangle reservoir. That way it does not seem to stick out so much. Overall I can see it cleaning up the fenders quite a bit. How are you going to route the lines?
I know there was somebody out there that justflat out mounted a ps pump with a on-pump reservoir on the driver side of the motor. I don't remember who though.
