SVO Injectors?
Old 06-10-2009, 10:18 PM
Counted Out's Avatar
Default SVO Injectors?
What do 30lb Redtop SVO injectors flow at with stock LT1 fuel pressure?
Sorry for the stupid question.
Old 06-10-2009, 11:38 PM
BLK,97,T/A,M-6's Avatar
the ford injector are designed to run at 30lbs at a fuel pressure of 35lbs. Gm lt1 cars have a fuel system pressure of about 42.5. This makes the 30# svo's run at about 35 to 37 pounds.
Old 06-10-2009, 11:53 PM
buffman's Avatar
More like 32lbs... (31.65lbs to be exact). You'll find the SVOs on LT1s on a bolt on setup usually start to get near 128 in the 32+ range.
Old 06-11-2009, 12:01 AM
Get near 128?
Sorry, still a newb.
Old 06-11-2009, 01:08 AM
MEAN LT1's Avatar
Originally Posted by Counted Out
Get near 128?
Hes reffering to your long term fuel trims. When you get a scanning program you'll be able to put 1+1=2.
Old 06-11-2009, 11:48 AM
myltwon's Avatar
30# svo's work fine on my 12:1 383 just for a point of reference
Old 06-11-2009, 11:54 AM
ss.slp.ls1's Avatar
(1 bar = 14.5037738 psi)
Our cars run @ 3 bar (~43.5psi)
IIRC, Fords run @ 2 bar (~29psi).
I am using stock Cobra 39# injectors. If you are getting a mail order tune, every mail order tuner should know how to tune for SVO 30# injectors, they are one of the most common injectors used on our cars.
Old 06-11-2009, 12:42 PM
buffman's Avatar
delta pressure for most all Ford Injectors are rated at 39psi....
Quick Reply: SVO Injectors?
