oil pressure problem
ok i pull into work this afternoon and i go around a corner at 10mph and the check gauges light comes on and i look and my oil pressure went to 0!!! once i straightned the wheel it returned to normal(think round 40) and went around another and it did the same thing.
edit
well left work(only mile from home) and it happened 3 times. it drops to 10 and quickly to 0 for about 3-4 seconds and then jumps quickly to 40. what in the world. weird
edit
It's not too bad. What I do is chain my engine to my STB and that allows me to drop the k-member out completely and doing the pan is easy then. Might as well do the motor mounts and install a new oil pan gasket while you are at it.
