can someone identify this seal !
Old 07-13-2009, 03:03 PM
monster81's Avatar
Exclamation can someone identify this seal !
i just finished assembling my short block using sealed power gasket set (part# 260-1650) and i was left with this seal not knowing what its for ,,its a white plastic seal about 7/8" diameter.
Attached Thumbnails can someone identify this seal !-dsc00298.jpg   can someone identify this seal !-dsc00277.jpg
Old 07-13-2009, 03:08 PM
the_merv's Avatar
I almost want to say the Water Pump Drive Seal.. that's about the only thing in that is that diameter..but that seal looks different.
Old 07-13-2009, 03:09 PM
RamAir95TA's Avatar
Oil pump?
Old 07-13-2009, 03:14 PM
the_merv's Avatar
I don't remember the Oil Pump having a Seal like that..
Could that be a Bushing for the Drive Shafts..either the Oil Pump or Water Pump?
Old 07-13-2009, 03:18 PM
airfix's Avatar
I dont think that has anything to do with the waterpump, atleast when I took mine off and converted it to electric I didnt see anything that even looked similar to that, I also removed the pump drive shaft and nothing like that. I looks like a bushing not a seal. Could it be for your oil drain plug?
Old 07-13-2009, 03:20 PM
monster81's Avatar
the water pump drive has a totally diffrent seal, and i dont think it belongs to the oil pump, my oil pump is already installed and this seal has nowhere to go on the pump !!!
Old 07-13-2009, 03:23 PM
ThreeHonks's Avatar
might be the oil level sensor seal/gasket
Old 07-13-2009, 03:24 PM
the_merv's Avatar
No..that one is thinner than that and a tan color.
Maybe that's just an extra piece of junk that got in the pack..
Old 07-13-2009, 03:27 PM
airfix's Avatar
wierd was there a seal/gasket list with the kit?
Old 07-13-2009, 03:32 PM
monster81's Avatar
could be a bushing since its plastic im not sure..i didnt know the drain plug has a seal,ill check that first thing when i get back home
Old 07-13-2009, 03:36 PM
the_merv's Avatar
There is a little O-ring or piece of rubber on the end of the Oil Drain Plug..nothing like that.
Old 07-13-2009, 03:42 PM
RamAir95TA's Avatar
Fire it up. If nothing leaks, hell with it!
:-D
airfix's Avatar
Yah I was just takin a guess bcz Ive seen plastic ones on import cars that look kinda similar to that pic. the one on my is is what you described.
Old 07-13-2009, 09:00 PM
94Aquaformula's Avatar
Its the oil drain plug gasket for sure. Have the same kit. 100% positive
Old 07-13-2009, 09:07 PM
1badzee's Avatar
Looks like a seal from an after market transmission pan for the drain plug..
Old 07-13-2009, 09:12 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Old 07-13-2009, 09:26 PM
airfix's Avatar
What does this have to do with his question. Comon dude.
Old 07-13-2009, 10:01 PM
Paul Bell's Avatar
I have NO idea how that got put there, removed
Old 07-13-2009, 10:41 PM
Jose93z28's Avatar
Looks like the oil drain pan bolt gasket for sure
Quick Reply: can someone identify this seal !
