4th gen to 3rd gen front end!!!
Old 09-30-2009, 06:32 PM
blk3rdgen91's Avatar
Default 4th gen to 3rd gen front end!!!
help I need to know if it is possible to frankenstien my 3rd gen with a 93 Z 28 front suspension swap.?????
Old 09-30-2009, 07:04 PM
chavez885's Avatar
Old 09-30-2009, 07:40 PM
TJ
TJ's Avatar
it is possible, and has been done, BUT.... it will take hundreds of fabrication hours.
what are you trying to accomplish?
3rd gen stuff works pretty well, IMO.
Old 09-30-2009, 10:00 PM
LT1
LT1's Avatar
In some cases ive heard that 3rd gen's handle better than 4th gen's.
Old 09-30-2009, 10:10 PM
robsquikz28's Avatar
Originally Posted by chavez885
hahahaahhaha
Old 09-30-2009, 10:23 PM
1994formulalt1's Avatar
3rd gens handle better than 4th gens imo
Old 09-30-2009, 10:59 PM
camar0corey's Avatar
Ha when I read the thread title I was thinking he wanted to put a square nose on a rounded vehicle or the opposite. Quite funny if you think of it that way, evokes a what is that person smoking thought.
Old 10-01-2009, 12:06 AM
Rockstar
Johnny-LT1-runner's Avatar
Why? That is ridiculous.
Old 10-01-2009, 12:35 AM
LT1
LT1's Avatar
Years ago someone did that on a 3rd gen Camaro it looked similar to the "1994 Callaway C8 Camaro". ill post a pic of it if i can find it.
Old 10-01-2009, 12:40 AM
Rockstar
I remember seeing pics of it one time. It was kind of awkward looking. Like a muscle car and Italian super car had deformed genius babies.
It was unique, but it was made in bad taste.
riceburnerZ28's Avatar
That's a bad idea!
Old 10-01-2009, 01:13 AM
flippincamaro's Avatar
Damn! Im with camar0corey on this one, I thought the same that the OP was wanting to put the 3rd gen nose on a 4th gen
Old 10-01-2009, 06:50 AM
I just really want to be able to use a rack and pinion set up not all this bs that you guys think...dont think too much into it . I have a 4th gen that im stripping down don't wanna sell parts if it's posible that i can use them.
Old 10-01-2009, 06:54 AM
I just want to put that rack and pinion set up from that 3rd gen I dont know if there is a possibiltiy of that
Old 10-01-2009, 05:50 PM
TJ
TJ's Avatar
its difficult to put a rack system under a 3rd gen without spending about a grand. the 4th gen unit will work with fabrication, but you will not gain anything.
look into a racecraft fabricated spindle. you will need the version with shortened steering arms. a stock spindle WILL not work for a rack and pinion setup. even in a drag car, a school bus will be able to turn circles around you.
stock tie rod arms are 3" too long from center of ball joiint to center of tie rod bolt hole.
Old 10-02-2009, 11:13 AM
z_speedfreak's Avatar
3rd gens handle better because they weigh less and have stiffer rear spring rates 4th gens front end are improved hence no wonderbar for us, rears are the same except for the spring rate.
Old 10-02-2009, 11:24 AM
phirepower's Avatar
what might be cool is incorporating 4th gen taillights into a 3rd gen body. Outside of that you're nuts junior, you're nuts!
Old 10-02-2009, 12:06 PM
Rockstar
lmao!
Old 10-04-2009, 01:10 AM
higgsfbody's Avatar
a 3rd gen should handle better than a 4th gen would b different i guess though
Old 10-04-2009, 01:13 PM
LSWHO's Avatar
I love how some of you are talking about swapping body panels. The OP clearly said suspension in the ONE SENTENCE you had to read to find out what he's asking.
I'd say it's probably a waste of time and just go with ugraded parts that are made for the 4th gen.
Quick Reply: 4th gen to 3rd gen front end!!!
