Prob with OPTI from thepartsladi???
I recently bought a new opti from the partsladi off of ebay...ive heard several people say they are good genuine opti's from GM. well i got it in, had my mechanic put it on, and it doesnt work. has this happend to anyone else? just wondering if i should allow them to send me another one or get my money back and go somewhere else? Mechanic said the fuel injectors where not getting a pulse from the opti, where as with the old one it was not firing. any help is appreciated.
Anyone can occasionally get a bad opti. Have them send another if you are sure it is the problem and not the electrical harness (it's not a bad idea to change that, too).
If you do send it back for a replacement, you will need the original box it came in. I have had no problems with our opti from them. They are original Delco products. With that said, it is possible to get any product new that is deffective. I would check your opti harness first though.
i got a bad one from them also... just called them and told them what the deal was and they sent me a new one... it just took a little while because they had to get the old one picked up and delivered to them before they would send the new one out, which is understandable
but yeah i would also recommend replacing the opti harness while you're at it just as added insurance
thanks guys, thats what i needed to hear. And this opti was not 70$ it was $260^^. ill look into that harness as well. I dont know much at all about the LT1s since i came from ls1's, so your help is apreciated.
Unless you know someone at the dealer, there is a good chance you paid hundreds of dollars more than is necessary. I've priced some stuff through my local dealer, and in comparison to what Jason Cromer charges for example, I felt as if I were being asked to shoot some lubeless gay ****. I was shocked the first time I did a price comparison between my hometown dealer and Jason.
alright how much are these harness's and do you have to remove the opti to install it? And yes i went to LT1 because my ls1 was rearend at 80 mph and the LT1 is/will be my DD in relief of my cobra. I do plan on upgrading to a ls1 DD very soon though....
No you do not have to pull the opti off to replace the harness. Here is a harness link.
http://www.optisparkharness.com/opti...s/default.aspx
