skip shift delete
This is just one of the skip shift eliminators out there (some are a bit cheaper). It's plug and play. It literally takes longer to jack the car up and get under it than it does to plug this in place. This is by far the best bang for your buck as far as aftermarket parts go.
http://www.summitracing.com/parts/SLE-21008/
Will that still throw a code if you scan the PCM? When i swapped to m6, i never wired the skip shift. I got it tuned out of the PCM, but when I scan it, it still comes up.
if you have skip shift tuned out via the sliders in the constants table, you still need to have the code erased. my car has no ac, no cc, no skip shift, no maf, etc. i have all the codes deleted from the pcm, so the computer can't throw an SES. Essentially, that particular component is completely erased from the pcm.
Does the skip shift wire from Speed Inc work on Autos? the paper telling you how to put it on only says on manual transmission why the way its describe makes it sound like it would go on an automatic.
Haha I didn't know what it was for, and the way they described it on speed "Easy 5 minute install, eliminates annoying computer controlled 1st to 4th shift." so when it said computer controlled 1-4 shift I thought of my car (an auto) shifting from 1st to 4th when I'm lightly on the gas. lol guess I was a noob and bought it :/
Just put the one you bought up for sale!
