Steering wheel removal ?
Just checking with you guys to see if there is anything else I need to do for safety when removing the airbag from the steering wheel? I pulled the 15 amp fuse from the panel inside the drivers dash area and removed the NEGATIVE cable on the battery. The car has been sitting like this since midnight yesterday. I assume 12 hours is long enough for any residual energy to be depleted. Can you think of anything else I need to do for the safe removal of the airbag.
I'm headed to autozone in a bit to rent the steering wheel puller so I can put my new wheel on
Check out the 4th paragragh on the first post in the link below. He's got it covered.
https://ls1tech.com/forums/general-m...oval-pics.html
"FIRST, disconnect the battery, then disable the SIR (supplemental inflatable restraint) system. To get to its connector you need to remove the panels underneath the steering column. They’re held in place either by bolts (8mm I think) &/or philips head screws. The SIR connector is the yellow 2-way connector under the steering column. Then remove the airbag by undoing the 4 hex screws from behind the steering wheel. Be careful not to drop the airbag, and you might as well be extra safe and place it face up away from anything important."
So actually there is a 3rd step. Remove the connector from under the steering wheel.
1. disconnect NEGATIVE battery cable
2. remove 15 amp airbag fuse
3. remove/dis-connect yellow connector under steering wheel in lower dash
Then proceed to dis-assembly.
This is the only time I have been nervous to do something to my car. I hate the airbag
ok i just did this on my 95 trans am and put a racing wheel one of those cheapy ones. be very careful and keep everything. i didnt and now i dont have a horn. plus rent a good tool dont buy the cheap 10 dollar one it broke for me. watch the lil spring 2 if i didnt where glasses i might of lost a eye
That's the connector. And you're correct:
1st - negative cable
2nd - airbag fuse
3rd - airbag connector
Also I would wait about 15 mins. before doing any work after you disconnect the battery just to make sure there isn't any residual charge. It's fairly straightforward but it takes a bit of time to actually get the bag off b/c the 4 bolts are in there pretty deep and your torx bit might not reach all the way in.
2nd - airbag fuse
Thanks for all the quick responses. I unhooked the yellow connector this morning and I will probably pull the wheel later tonight.
Perrco,
Thanks for the heads up on the race wheel, but I'm replacing my factory with a custom wrapped black alacantara, black perforated leather, red alcantara 12:00 position, and a red chain stitch. The wheel has also been converted from charcoal to black. ( I will remember to wear safety glasses )
I8ASaleen,
I'm getting the car ready for that roll race on the Dallas North Tollway I'll be ready for the dig race as well. Just trying to tidy up the line lock & the two step for the slicks. I don't want to get caught slippin'
here are some pics of the wheel in case you guys have not seen the thread in appearance and detailing:
Perrco,
I8ASaleen,
Oh man. I'll be getting mine back tomorrow or the next day. May have to make a run with open headers lol. I've been spending all my money on my daily to get it in sellable condition, but I'll be getting a fat $5,500 check next week! I may lose the first time but watch yoself next time!
I will still agree with your initial assessment. Our cars will be a hell of a race for pure bolt-on LT1's My car has been running absolutely nasty since I got my MSD DIS4 ignition box hooked up again. The car is just killing the drag radials in first. I actually ran into a black 2006 GT with the 500 body kit (the car looked stunning) on it, (manual, headers, exhaust, CAI, and gears) and I completely broke that thing in half. I know the 05/06's don't really run that well, but it's still fun to get a quick romp with a newer stang.
PS: don't run open headers. The knock retard is ridiculous, just open the cut-out for the extra 10 ponies
I will post pics in the next couple days of the steering wheel install. I just finished and it looks sweet !
