Piston Question
Piston Question
Hey guys im trying to figure out if my pistons when i put them into the compression calculator is + or - cc? May sound like a noobie question but not sure as the site says its a 5.00cc piston and my engine guy thats putting my recently picked up shortblock back together and wrote down the the pistons to be -5cc on specs of my engine. This makes a huge difference in compression calculating!
Here's the link to the pistons:
http://www.summitracing.com/parts/MLE-SBC250030F05/
Like said before it depends on the compression calculating program. Those pistons you linked to are flat tops so anything taken out of them makes them +cc. However I've seen flat top pistons with valve reliefs that were call -cc. fex77k above is talking about a Wiesco "flat top" piston with a 13cc relief cut into it, a 13cc relief is a whole crapload of space.
Summit is correct in calling it a +5cc piston, put it into your calculator both ways, the lower compression one is the correct one.
Also what stroke crank are you going to use, what rod length, what is the compression height, how far in the hole is the piston going to be, what thickness head gasket (compressed), and what size combustion chamber.
Edit: So I guess you are using a 6" rod and a 3.48" stroke?
Bore: 4.030
Stroke: 3.48
Deck Height: 0.007
Gasket: 0.039 or .029(Will know when we check the clearances if i run the thinner gasket)
Gasket Bore: 4.125
Heads: 64cc (Contemplating milling 0.020 off to 60cc)
Im using Eagle 6" H-Beams Rods with those pistons and a stock crank.
This is the calculator im using:
http://www.kb-silvolite.com/calc.php?action=comp
Says with a +5cc piston ill be at 10.2 vs -5cc piston will put me at 11.5. I know it sounds like more of a +5cc but just double checking to be sure. More then likely im going to mill the heads to 60cc to bump it up to 10.7. Depending on when my engine guy puts the heads on the motor to check the clearances we might be able to use a thinner gasket on it bump it up to 10.9.
Stroke: 3.48
Deck Height: 0.007
Gasket Bore: 4.125
what type of heads are you using? 64cc is a lot for most LT1 heads.
the stock compression is 10.4 most guys with no interest in a boosted car will run into the 11s with no worrys and on some strip car run into the 12 easily with pump gas
I have a stock crank, 6" rod, Mahle power pack bottom end with LE2 heads and the impala .029 gasket, the deck is stock. compression was 11.3-4
Either that or just find a different calculator that instructs you which way to enter the valve relief volume. There are a lot of calculators on-line to choose from.
Jake
