Need to ID this Cam, Help Please
I picked up a used LT1 that has a fairly new aftermarket camshaft installed. I don't plan to run this cam but will list in the for sale section if I can ID it.
The only part numbers I've been able to find on the cam are
071 FM30
152 02R
Lift with 1.6 rockers is .544 on both Intake and exhaust.
I've searched this site and about an hour on Google with no luck. Thought maybe someone would recognize it.
Thanks for any help.
071 FM30
152 02R
Unfortunately cams may be marked with several cryptic #'s or alphanumeric sequences. It may be from the cam grinder, the reseller, or the cam core manufacturer.
We CAN however determine what it is by physically measuring it. We charge $25 to do that for guys who care to send their cams in. With data we can quickly make either associated component recommendations, recommend a different grind, or just provide you w/ accurate documentation so you can sell the cam online etc.
Good luck!
Good luck!
I've got a CC305 that I just pulled out of my engine setting right next to it and they don't look the same. I didn't measure each one to compare but my CC305 looks like a cast core and the cam in question looks to be a billet core. I think I just will send it off to AI to be measured, that way I can sell it.
071 FM30
152 02R
071 FM30
152 02R
Thanks,
Mike Sanford
Ancient thread, but its most likely a CC305. Not many single pattern LT1 cams (LPE and CMotorsports had a few back in the day) but the 305 would be the most common with a dual .544" lift on a 1.6RR.
