any lt1 guys running e85?
Old 11-23-2010, 07:00 PM
robsquikz28's Avatar
Default any lt1 guys running e85?
if so how do you like it?
what did you convert to do so?
any gains before and after with same combo?
why did you convert?
any nitrous guys?
who tuned it?
Old 11-23-2010, 11:00 PM
Wicked94Z's Avatar
I'll be hitting the 1/8 on thursday and saturday next week, I should be done dialing this thing in on the street by the end of the week. Bumping the compression and cam size has made this motor come alive big time. I'll be trying a 100-150 dry shot if I can squeek a good 60' and 330' on motor. Still haven't gotten my cage welded in, so I don't want to run a full 1/8 if it's not a good pass.
Old 11-24-2010, 12:18 PM
what size injectors and pump you running now?
Old 11-24-2010, 04:25 PM
Wicked94Z's Avatar
Fuelab 41402... my flow sheet says like 170gph at 43.5psi, and I'm running 60# motrons. I need to step to 83s i think when i start spraying 200+, I don't like the idea of running the pump at 70psi. The pump has a built in controller, I run it off a 12v output from my dfi box to dial the pump back to 50% below 4000 rpm and 40% throttle. The A1000 is only good to about 750 on E85 IIRC, but any pumps bigger than that will need a controller on the pump for street driving. I don't know if the magnafuel pumps are rated for alcohol yet... but if they are that's another option.
Old 11-24-2010, 05:29 PM
kgkern01's Avatar
I have a little more tame build than Wicked, 226/226 custom LE cam, 11.7 SCR, stock bottom end, with EB Ported LT1 heads. Also running Walbro pump, 60# injectors, although some 50#'s would have been the ideal size for my build, the 60#'s were cheaper, and 42#'s were too small. Haven't dynoed or got a run at the track yet. Plan on doing that in the spring, along with 58mm TB and ported intake, as with the stock TB and intake I cant get over about 97kpa at WOT.
To setup on E85 you need a wideband O2, you can start with a gas tune, but then change your injector constant initially to 70-75% of your injector size to trick the PCM into adding the necessary extra fuel, then tweak it from there. I would suggest learning to self tune your A/F as the blends change summer vs fall/spring vs winter and you will need to be able to adjust your A/F as needed. I would suggest at least a Walbro pump or more depending on how much power you plan on making.
Old 11-24-2010, 09:22 PM
gregrob's Avatar
Good idea but you also need to buy a tester and make sure every batch you put in is 85%.
Every batch I've ever tested from my local station has been 85. But I dont use it in the winter so...
Old 11-24-2010, 10:01 PM
Pony Exp.305's Avatar
I have a friend who run LT1 Camaro had tried use on E85 mix w/premium gas. Run rough and not good run. Stop use on E85 then got better run with using +91 octane gas.
E85 good with high compression like above +10.5-1 or more with large injectors and fuel pump. .
Good Luck on LT1 using E85..
Old 11-24-2010, 10:02 PM
gregrob's Avatar
LMFAO
Old 11-24-2010, 10:34 PM
Tensec94z's Avatar
I run E85 with 60 lb injectors on a 383 with 10 to 1 compression,no modifications to the fuel system at all but a walbro 255 in tank pump,car is running 10.80 at 123mph in the quarter mile,I love this stuff and its less than $2.00 around here.
Old 11-24-2010, 11:12 PM
Wicked94Z's Avatar
i hate you... i paid 96 dollars for 33 gallons two days ago damn california sucks
Old 11-25-2010, 12:10 AM
Last I saw is that e85 IN chicago is $3 a gallon or I can drive 30 min away and grab it for $2.60 gallon.
Old 11-25-2010, 09:48 PM
kgkern01's Avatar
Umm, what?
E85 mix with premium of course won't run right if not tuned for the exact mixture of gas+E85, you are changing from gasoline to (mostly) alcohol, a completely different fuel, you can't just put it in and try it... All LT1's are
, well close, 10.4 stock, but yes, the more compression, the better the gains from E85. I (and many others) have been running ONLY E85 for a long time and running clean, great, and strong at that.
I have been getting it for about $2.68/gal lately, it has definitely gone up as the mixture has changed to the winter blend
Old 11-26-2010, 12:25 PM
kgkern01's Avatar
The Thornton's station by my house just hada Black Friday sale, $0.85/gallon for E85! Just filled up the car and 7 gallons in fuel jugs for about $14!!!!
Old 11-26-2010, 02:42 PM
Wtf what state is that iN?
Old 11-26-2010, 05:34 PM
lifeisgood's Avatar
E85 is right around @ bucks here.lol
Old 11-27-2010, 06:20 AM
kgkern01's Avatar
Yup in Jeffersonville yesterday.
Old 09-09-2015, 12:46 AM
Brfirebird91's Avatar
Hey dude pretty old post but just seen this thread and I plan running E85 on my LT1 12:1 compression with a 200 shot. What size injectors do you think I'll need. I am also gonna try out the AEM E85 fuel pump and AEM Wideband. Think I'll be ok 60lbs.??? Or will I need bigger don't know much of this.???
Old 09-09-2015, 05:10 AM
bufmatmuslepants's Avatar
He hasn't posted for a while, might have better luck PMing him and see if he gets it in his email.
Old 09-09-2015, 06:02 AM
Man-Crush Warning
Shownomercy's Avatar
Talk to Dawdaw over on LTXTech.
Old 09-09-2015, 02:34 PM
BIGsmokey10's Avatar
How much flywheel hp you looking for?
And just to specify when you say your gonna do a 200 shot is that wet shot or dry ?
Quick Reply: any lt1 guys running e85?
