Water leak from front of motor
Old 11-25-2010, 05:47 PM
Lawhead's Avatar
Default Water leak from front of motor
Well today I notice this puddle after starting my car and letting it warm up while i had to run back into the house and there is a HUGE puddle rear the front.
Seems to becoming from the timing cover but not sure what could this be
What a fantastic thanksgiving huh?!
Old 11-25-2010, 06:20 PM
letsrun97z's Avatar
Check the weep hole under the waterpump
Old 11-25-2010, 06:35 PM
TheTransporter69's Avatar
or any of the hoses around that area there are quite a few.
Old 11-25-2010, 06:39 PM
Lawhead's Avatar
Its none of the hoses and its not the weep hole :/ checked them both. Uncle said its coming from the intake area when he put headers on my car............guess this 355 is begging to be built
Old 11-25-2010, 08:27 PM
robsquikz28's Avatar
U didnt say in your post. IS it OIL OR A/F?
Old 11-25-2010, 08:29 PM
letsrun97z's Avatar
^^ in his header it says water leak
Old 11-25-2010, 08:52 PM
sweetbmxrider's Avatar
our intakes don't have water in them. maybe he noticed something in the steam pipe area? i would either pressure test the system or start looking real hard at every water connection with a light and a mirror. it shouldn't be that hard to source the problem.
Old 11-25-2010, 08:58 PM
Lawhead's Avatar
Well taking the water pump off started doing it tonight but stopped because of light issues noticed that the bolts were no where near tight like took 0 force to break them loose maybe the source of the problem?
Old 11-25-2010, 09:25 PM
RamAir95TA's Avatar
Loose water pump bolts = leak. Pretty certain there. Add in lack of thread sealant on the threads and you've got a leak. Simple.
Old 11-25-2010, 09:26 PM
Lawhead's Avatar
well ill go back out there tomorrow tighten them real good and see if she leaks. just dont know why they would come loose like that. I mean there weren't finger loose but no where as tight as i thought they would be
Old 11-27-2010, 10:46 AM
97LT1's Avatar
x2. I had a small amount of seepage going onto the pump housing after my fresh build.( used thread sealant also) After a quick bit of extra torque on that one bolt, everything sealed up.
To the OP if tightening up does not work, take out one at a time and put some thread sealant on each one. (it will be messy because coolant is going to flow out) Being you working with wet surfaces, you should consider a sealant that does not cure.
Old 11-27-2010, 01:07 PM
Lawhead's Avatar
Yeah going to take the pump off today and look for the stain where its coming from and seal it up good and try that
Quick Reply: Water leak from front of motor
