Considering Different Piston Rings
For the 398 CID LT1 build I'm into, I'm consider using piston rings I haven't used before and am hoping someone has used them and will give me some feed-back on them.
They're: Speed-Pro R-19100s and Perfect Circle 315-0036
I'm going to write this last part, even though I know up-front that it won't be heeded, but I'm only looking for feed-back on those two rings. Not alternate/substitute recommendations like "You should use blah, blah, blah". PLEASE!
Thanks,
Jake
Thanks,
Jake
Well, seems no one knows about those two piston ring types. Guess I'll check on a few other Forums; maybe someone there has run them or can give me some feed-back on their pros and cons.
Jake
Jake
Once I start down that road I'll be receiving personal preference responses and won't get feed-back on the rings I'm considering.
Jake
Obviously no one knows. That's okay, not a problem; there's nothing wrong with 'not knowing'. So far I've received several responses from members on other Forums who are familiar with those two sets, I'm just looking for a few more. Just part of the 'homework' I do when considering such a move as I am now.
I'll just keep asking around until I find some more members who either know from personal experience or who can point me to tech articles where the pros and cons of each make are discussed.
Jake
Jake
