How much can you spray on a stock LT1 and how much gain.
I am planning on putting a small hit on my wifes car and was wondering what kind of gain I should see. Also I do not want to put on a kit I will probably piece it together with all the stuff I have already. But what should I see with a 100 shot or so. And do I need to add a module to take out timing or something like that. Thanks
What all was done to it to run 13 teens.
also if you do run nitrous you will want to run an ignition box that has rev limiter, the lt1 pulls fuel at the rev limit instead of spark, and that can potentially be a disaster if you hit the factory limiter while spraying
again sounds about correct.....I ran a 175 shot on a friends bolt on ls1 camaro and went from 13.0 @ 108 to 11.7 @ 122
agreed
I normally hose mine with the 150 shot and run low 11's but last time out we pulled a 10 sec time slip with a bogus 60' on the 150 pills and I told the boys if the car hits low 11's I would hose it with 200 pills. So when it went low 11's thats what I did. LOL With the 200 pills it ran another 10 sec pass. Thats on a stock bottom end, stock heads with a hotcam.
Thanks! Oh trust me I am! I guess I should have clarified I don't suggest spraying a 200 shot on a stock bottom end. LOL It was one of those days of the car is running so good just how fast can we make a hotcam only LT1 go today...
I'm very interested in this thread also because I'm considering doing a mild cam-only setup this summer and maybe throwing a 100 shot on the car for a fun car until I graduate college. My only worry is my engine has 110k on it now, but then again, I'm very cautious and conservative
X2, vTec runs a 250 shot with a DP i think.......anyone know for sure??
Regardless its a stock shortblock in a 3gen running 9.40's @ 140+
Pull some timing and get the safety items and your fine with a 100-150shot.
Want to bless my car for me?
