Head gasket and Timing Set
Old 12-15-2010, 04:45 PM
Choppers's Avatar
Default Head gasket and Timing Set
Which head gaskets would you run with a stock lt1 with le3 heads?
Also which timing set?
Old 12-15-2010, 05:28 PM
fex77k's Avatar
impy's if you want to bump up the compression a bit.
Are you going with a EWP, if so any quality dual roller will work.
Old 12-15-2010, 05:47 PM
RamAir95TA's Avatar
An LT1 is far from stock with LE3 heads. Clarify. If there's any sort of higher compression/power, I'd use Cometic MLSs.
Timing set depends on what you're using for a water pump, and whether or not you've got a vented opti.
Vented opti, EWP, and a 95 timing cover = Cloyes 3145 double roller, hands down.
Old 12-15-2010, 06:19 PM
AChotrod's Avatar
pretty sure you have to fly cut stock pistons or use aftermarket pistons with bigger valve reliefs for LE3s.
Old 12-15-2010, 06:25 PM
Choppers's Avatar
Man now. I am lost. Been told that with le3 heads and the cc503 cam it would be ok and then some say it can't be done on stock pistons. Guess I am going to call Lloyd tomorrow and clarify. Which MLS Gasket thickness should I get if these heads will work and also I do want to run a EWP. The motor is a 96 so I don't know if the opti is vented or not.
Old 12-15-2010, 06:26 PM
95mysticta's Avatar
That is true i didnt think of that till you said it...
Old 12-15-2010, 06:27 PM
AChotrod's Avatar
ya your opti is vented and I run a EWP. Says that about the LE3s right on LEs site
Old 12-15-2010, 06:34 PM
Choppers's Avatar
Ok. I will call Lloyd tomorrow and ask whats up. I was looking on Summits website and they had 3 different Cloyes 3145 sets. Which do I want?
Old 12-15-2010, 06:54 PM
ScrapSilicon's Avatar
if its a Cloyes dbl tru roller for lt1 should be http://www.summitracing.com/parts/CLO-9-3145/
Old 12-15-2010, 06:55 PM
Choppers's Avatar
So do I need the 95 timing cover or will the 96 I have be ok?
Old 12-15-2010, 06:57 PM
95,96 and 97 should be all same ..not sure on 95 obd1 motors tho ..damn work comp crashed out sorry about edit after edit and yes on the interior
Old 12-15-2010, 07:07 PM
RamAir95TA's Avatar
96s and 97s have the provision for the CKP sensor. You can use either cover, but you'll have to find a way to plug the provision. Ideally, the 95 cover is the best to use.
Also, I don't know why you'd use LE heads with an off-the-shelf cam. Why not go with whatever LE recommends?
Old 12-15-2010, 07:08 PM
Choppers's Avatar
iIth the deal I got on ls7 lifters and cam you can't pass it up. Also got a steal on the heads and intake.
Old 12-15-2010, 07:14 PM
RamAir95TA's Avatar
I'll never understand how saving a few bucks can be more important in a build than achieving or even surpassing your goals.
Old 12-15-2010, 07:16 PM
Choppers's Avatar
All I wanted was 400 rwhp. I think i'll be pretty damn close. What you think?
Old 12-15-2010, 07:19 PM
Choppers's Avatar
I paid $250 for the ls7 lifters and cam which are new. Can't beat that IMO.
Old 12-15-2010, 07:22 PM
RamAir95TA's Avatar
Maybe, maybe not. You never know. I know it would be much easier (and far less guesswork) if you had a custom grind designed to do what you want.
Like I said, I don't understand how saving $$$ can be more important than reaching your goals, especially when spending a bit more would ensure it. JMHO.
Old 12-15-2010, 07:32 PM
AChotrod's Avatar
sell your cam and put the money towards a custom LE cam.
Old 12-15-2010, 07:46 PM
Choppers's Avatar
I may end up doing that. My goals were a clayton forged short block but 3k is alot to fork out when I have a running lt1 now. May just sell the cam and build another motor on a stand.
Quick Reply: Head gasket and Timing Set
