Deleting smog pump!!!!
I have a 96 z28 camaro. I have a few questions bout the smog pump? I took it off threw in trash so all the vacum lines that went to it i can follw thos back to egr vavle and throw those in trash rite and all the ones that go from smog pump to intake i can throw those away to rite. But there is a couple im concerned bout there is one goes from smog pump to this valve looken thing thats bolted on with coil and it has a plung in senser can i throw that valve thing away to? And theres one more that comes from egr to another valve looking thing that the vacum line plugs into and its bolted to the intake with a senser plug in to so can i delete this vavles? Thanks guys need more info let me no thanks
The smog (AIR) pump and EGR are two completely unrelated systems and share no common components.
The connector/plug you're seeing are part of the AIR pump recall components, and they can also be trashed. The EGR valve and solenoid can all be removed and blocked off using block-off plates. Keep in mind though that since you have an OBDII car you will need programming to clear the codes or else you'll get SES lights out the ying yang.
Well im not to worried bout emissions im in a no emissions county but i will have it tuned out this is wat im working is tune and so i can work on everything easier to so all that stuff i pulled of is ok rite or do i need to put back on lol
Man on a iphone and i **** up alot on typing. So whAt am try to say is i did ask what to take off cut me some slack first car first time. Im sure u were in the same boat but oh well aint on here to talk **** on here to learn bout cars and knowledge u guys have to offer? Neways what does air, and what does it do. Is there a diagram u guys can show me a diagram what to keep and not to keep on car?
For deletion of everything, see this thread: https://ls1tech.com/forums/lt1-lt4-m...tuff-help.html
The AIR system aids in pre-heating the catalytic converters on cold startup.
