Was looking for a name of this mod to a lt1 air filter help??
Old 12-27-2010, 05:52 AM
TheN3wGuy's Avatar
Default Was looking for a name of this mod to a lt1 air filter help??
i was wundering what this kind of filter this was called cuz i know ram air , is a box type with a square filter n cold air intake is in the side of the car, but i was wundering what this kind was called, its sorta ram air, but then kinda not, and i also was wundering if i did this wud it improve HP, and would i need a new hood? cuz i have stock hood(ill put up pic).
STOCK HOOD
Old 12-27-2010, 07:46 AM
BlackBird87's Avatar
Dont bother with it, Since you wouldnt be using the maf with that filter you would need a different tune. Just stick to a normal cold air intake.
Old 12-27-2010, 08:42 AM
VinR1's Avatar
if you have a '93 or a speed density tune, you could run a filter off the tb like that
K&N either 5000 or 5050. Both will fit without rubbing your factory hood and I'd suggest the 5050 so there's enough room on the back side to make a hole for your IAT sensor
Old 12-27-2010, 10:13 AM
defaultexistence's Avatar
IMO that would hinder any gains on HP due to it sucking hott *** no OXY hav'n air LS1 lid mod w/core support murder FTW
Old 12-27-2010, 11:07 AM
05HD's Avatar
That is called the HAI or Hot Air Intake.
Old 12-27-2010, 01:28 PM
SexyTransAm's Avatar
this will work better
http://cgi.ebay.com/ebaymotors/3PSI-...Q5fAccessories
Old 12-27-2010, 03:43 PM
hitmanws6's Avatar
that style intake is taken from the impalas, its made by clear image. however theirs has a heat shield and retains the MAF. get a normal CAI or do the lid conversion
Old 12-27-2010, 04:20 PM
Originally Posted by SexyTransAm
^^^YUP! FTW!!! seriously lmao
Old 12-27-2010, 04:27 PM
hitmanws6's Avatar
More like .0000000000000000002 psi
Old 12-27-2010, 08:59 PM
trilkb's Avatar
forget the intake, thats a L98 tpi motor with coil packs...very intresting!
looks like a s10 swap?
Quick Reply: Was looking for a name of this mod to a lt1 air filter help??
