LT1 intake manifold question
Is there any differance between a 1994 intake and a 1996? Headed back to the junkyard to pick up a few things in a few minutes and wanted to know if the intakes were the same, if so ill pick up the 1994 intake.
Nothing I would bother with or worry about though, they are in in essence the same - except for the 93's as Ramair mentioned .
So how about this then, I got the intake and now im looking at all the crud built up inside. Is there a way to treat the intake to clean all the carbon/crud build up inside of it?
One more question, is there a shop that is known for porting LT1 intakes? Id like to get this ported and powdercoated so when i pull my stock intake to fix the oil leak i can replace it with this one.
