Stall Question
Old 02-01-2011, 10:53 PM
Big Bad Bud's Avatar
Default Stall Question
Was going to do the Yank 3600 that so many brag about, but has anyone used this?
http://cgi.ebay.com/ebaymotors/4L60E...item1e61168c64
Old 02-01-2011, 11:17 PM
Gojira94's Avatar
LS1Tech 10 Year
Earlier discussion of these folks:
https://ls1tech.com/forums/lt1-lt4-m...ard-stall.html
Some have had great luck on mild to moderate builds, I'm holding out for Circle-D 245mm 3200 since I'd want a couple of upgrades these RevMaxx folks would recommend, and would only be a couple hundred less than a Curcle-D...
Old 02-01-2011, 11:28 PM
pboxfun's Avatar
I've got a 3200 from them! Great product and people to deal with!
Old 02-01-2011, 11:44 PM
Thanks for the input!
Old 02-02-2011, 03:41 AM
Wicked94Z's Avatar
just because we might run into eachother at the dragstrip some day... i'll go ahead and give them a two thumbs up recommendation.
Old 02-02-2011, 06:13 AM
Badazz 97 TA's Avatar
is it the one in the top picture or the picture below? i would save your money. when you cheap out on an important item like a converter it usually will bite you later on. it doesnt mean you have to go with just yank. theres other good companies out there. This is an item that could give you better results then the cam you put in. dont cheap out.
Old 02-02-2011, 07:47 AM
96TransAmboosted's Avatar
I agree with the circle D....
Old 02-02-2011, 08:14 AM
01ssreda4's Avatar
The top picture is what appears to be a billet converter. You will be buying the one at the bottom. Look in the auto transmission section, in the sticky and see "torque converter education" thread. There are also a couple of big revmax threads that turned into huge pissing matches that are interesting reads
Quick Reply: Stall Question
