Victor Reinz .026" LT1 gaskets
Old 02-23-2011, 09:50 PM
BOLO's Avatar
Default Victor Reinz .026" LT1 gaskets
Anyone know the part# for these gaskets? I know the Mr Gasket ones are #5716. Thanks, appreciate it.
Old 02-23-2011, 09:53 PM
gregrob's Avatar
5898 I believe
Old 02-23-2011, 10:44 PM
fergymoto's Avatar
5898 is correct.
Old 02-23-2011, 10:46 PM
MattSapp95_T/A's Avatar
yeppers 5898 used them several times with no problems
Old 02-23-2011, 10:53 PM
Matts94Z28's Avatar
Where are you guys ordering from? I am picking up my ported heads this weekend.
Old 02-24-2011, 12:37 AM
BOLO's Avatar
These Victor Reinz 5898 .026" can only be used under 12:1 CR? What if you're running a cr above that like 13:1 or so?
Old 02-25-2011, 05:42 PM
355z28's Avatar
I use them on my 12.3:1 motor. No problems in the last 8k miles.
Old 02-25-2011, 06:39 PM
Moderator
BizZzatch350's Avatar
You can also use the B-body "Impala SS" gasket
Old 02-25-2011, 07:03 PM
fergymoto's Avatar
That's what the Victor 5898 is.
Old 02-25-2011, 07:18 PM
gregrob's Avatar
Nope. 5898 is .026
The impala is .029
Old 02-25-2011, 07:21 PM
fergymoto's Avatar
If you look up Impala head gaskets in the Victor catalog, the 5898 is the number given.
Old 02-25-2011, 07:56 PM
Moderator
JasonShort's Avatar
BOLO, you might want to check out the Cometic's. That is what I use. You can get a .027" from them and are much stronger being MLS than the GM impala gaskets (in my opinion). I would also recommend using a light coating of copper spray gasket on them prior to install.
Cometic's are significantly more than the GM Impala gaskets, but it's cheap insurance at this performance level.
Old 02-25-2011, 08:00 PM
gregrob's Avatar
Im going to run the Cometics in my new engine. I hear good things about them, especially with a healthy shot of nitrous.
I will say that the block deck surface and the head surface need to be very true for them to seal well.
Old 02-25-2011, 09:52 PM
TravisMcGill2000's Avatar
R thes any better than the mr gasket set. Were yall orderin this at?
Old 02-25-2011, 10:17 PM
ThreeHonks's Avatar
cnc motorsports has them.
Old 02-26-2011, 11:16 AM
camarolvr69's Avatar
they can be ordered from vatozone. just picked mine up friday. i initially went to advance and they were like victor who? lol said they've never even heard of the brand...
Old 02-26-2011, 11:41 AM
brokenbird's Avatar
this is where i ordered mine shipped fast
Quick Reply: Victor Reinz .026" LT1 gaskets
