383 is finished up
383 is finished up
Today I went to the engine builder and picked up my motor.
Motor is a:
383 with Eagle H beams, Eagle 4340 crank, and SRP pistons
LE custom grind 234/242 .579/.577 110LSA
Comp lifters
Stock heads with a mild port and polish with a 5 angle valve job
Patriot Gold Extreme valve spring kit
Howards 1.6 RR's NSA
ARP 7/16 rocker studs
guideplates
Melling oil pump
ARP head bolts and main bolts
Soon to come:
Speed Inc tune
SS3600
42lb injectors
Motor is a:
Comp lifters
guideplates
Melling oil pump
Soon to come:
Speed Inc tune
SS3600
42lb injectors
I'm not saying that the reading is right but thats what i was told. We will see when it gets tuned a LE2 head with that same combination should be about 420-440whp from what i've seen. So if the heads flow whats claimed then i should produce similar power.
