steering intermediate shaft
i just pulled my intermediate shaft because there is some play in the rag joint. i was going to order a rag joint eliminator but was wondering if i can just use a 98+ ls1 intermediate shaft instead? guess im just wondering if the connections to the steering column and rack are the same
so its the link between the steering column and the intermediate shaft that is incorrect then? i dont see why i couldnt use the lt1 joint from the top u joint up and the ls1 from there down correct?
