True Duals and Eibach Pros, what to do?
1 Post
So right now i am faced with a problem. I am installing true duals in the next week or two. I am going to be using the universal summit kit. I was origionaly going to go with a 2.5 inch set up. The only problem about this is that I would want to go bigger for when I build the motor up. I want to get the 3 inch kit, but im sitting on eibach pros/bilstein shocks. I want to get qa1's in the future, but dont have the funds for them right now. How bad do you think my ground clearence will be with a 3 inch kit w/ dynomax bullets on my current suspension set up? Would I be able to ride around with the 3" for a month or two until i can re due the suspension? I am also installing a umi adj t/a to help with ground clearence.
Any feedback is very much appreciated
3in all the way back with 4in magnaflow round mufflers and its dropped on eibachs out back with qa1s and qa1 coilovers up front.
https://ls1tech.com/forums/lt1-lt4-m...-pics-vid.html
