Magnaflow True Dual under the axle...pics/vid
Exhaust is finished! Took it to a local shop and the guy did a great job with mounting the dual exhaust and running the pipes under the axle out the back...yes under the axle. The header collectors and the the body of the xpipe are the lowest part, at about 2.5 inches of clearance each, so running it under the axle didnt lose me any ground clearance. I must say the tone on the exhaust is perfect but now that my hearing miraculously came back it may be a bit too loud for me, we'll see after a few more drives. BTW this is the dual exhaust with magnaflow round mufflers that Colin(Colin91z) ran dumped on his car for awhile.
More pics from underneath-dont mind the mess on the rear end, need to address a leaky pinion seal
Video
http://www.youtube.com/watch?v=in3hnNiTVYE
Video
He already had it off the lift when i went to pick it up and it was too damn cold to take more pics than i did. When i get it back in the air to swap out wheels ill make sure to take some underneath pics but ill run out to the garage now and see what i can get
So yea im thinking this is going to be too loud for my liking even with running it out the back and here i thought the magnaflow would be quieter than my friends same setup with dynomax bullets. I love the tone so need to figure out how to bring the volume down but get the same sound, just not sure if another pair of magnaflow round mufflers before the tips will do the trick.
Ive noticed that...couldnt explain why
Theres actually about 1.5in of clearance from the sway bar to the tips so unless im going dukes of hazard i dont foresee an issue with it.
Yeah, there is kinda a reason exhaust pipes always go over the rear.
