Would this be considered quite a bit of porting??
Measured with the best i had didn't have a micrometer to measure so i had a few nails i filed down to where they fit into port holes on the exhaust side.
The new motor has a 1/4 of an inch taken out width wise and height wise.
so that a lot or not much at all??
if it is those heads from the motor you just bought then they weren't profressionally ported but the guy did seem to open them up quite a bit. for what it is worth they did help knock off a couple tenths to get that 6.9x pass on your time slip. see if you can get some pictures of the ports.
Village Troll
Why are you wasting your time with filing down nails and showing these pics? Just put the thing together and run it. Make sure you don't have such a horrendous exhaust leak. Hell it looks slow anyway.
I was bored sitting in the shop? lol just wanted to know if a 1/4 inch is considered "a lot" of porting
Just asking as many questions as possible about the motor looking for a stall right now not sure which way im going with that but other then that it will be ready to put in
and on the exhaust leak ive heard of people porting there own heads to where there header won't seal it and has exhaust leaks
Village Troll
