Burning oil bad
Old 04-14-2011, 12:43 PM
Mitch383LT1's Avatar
Default Burning oil bad
lt1 is burning oil badly only 4000 miles on rebuild whats some things i could try do before tearing it down and replacing rings?
Old 04-14-2011, 12:44 PM
draggin97s10's Avatar
Intake gaskets?
Old 04-14-2011, 01:14 PM
djjab57's Avatar
How did you break the new motor in ???
Old 04-14-2011, 01:22 PM
Fazz73jr's Avatar
Try to narrow it down to cylinders. Pull spark plugs to see what's wet. Maybe valve seals or an intake gasket.
Old 04-14-2011, 06:24 PM
RamAir95TA's Avatar
Very important question...
Old 04-14-2011, 07:34 PM
96capricemgr's Avatar
What are the specs on the engine?
Old 04-14-2011, 08:27 PM
l 95 Trans Am l's Avatar
Anyone else but me think valve stem seals?
Old 04-14-2011, 08:44 PM
Valve seals are possible, as are intake gaskets,, rings/pistons, irresponsibly ported heads can even suck oil through an overly thin port wall. Lack of sealer on the intake rocker studs could even do it
Old 04-15-2011, 07:52 AM
quik95lt1's Avatar
thats my first guess.......and for $30 and an afternoon of work its worth a shot....IMO
yep......my port walls break into a few of my rocker bolt holes.......something like that could do it but i dont think it would burn THAT much...........rings could happen but i would say there is another issue at that point.........im leaning towards intake gaskets or valve seals.....
Old 04-15-2011, 10:36 AM
I just use teflon sealer on the exhaust rocker studs.
Old 04-15-2011, 12:30 PM
qc97z's Avatar
Anybody thought of running a compression or leakdown test?
hmmmm.....
Old 04-15-2011, 01:26 PM
How can intake gaskets leak oil? There's no pressure to push it threw.
Old 04-15-2011, 02:45 PM
HMMM. your right but what does a cylinder do on the downstroke? maybe sucks air though the intake?????? oh yea it does.
Old 04-15-2011, 03:58 PM
RamAir95TA's Avatar
Hey thanks for answering our questions.
Old 04-15-2011, 04:16 PM
Village Troll
SS RRR's Avatar
http://youtu.be/-aJROW6cuEM
Old 04-15-2011, 04:23 PM
An intake gasket leak to the lifter valley will suck oil. Had a set of blue Felpro gaskets delaminate the silicon bead from the paper and this happened. I like the gray gaskets better.
Old 04-15-2011, 08:41 PM
fex77k's Avatar
You can really mess up the install, and loose a bit of oil out of the china rails and the bottom of the intake runners is right there in the in the lifter valley. Likely no, but I've seen it done.
Quick Reply: Burning oil bad
