Gauges
Old 05-10-2011, 04:30 PM
Camaroking1996's Avatar
Default Gauges
What 3 gauges would you recommend for a H/C/I with full bolt ons?
Old 05-10-2011, 04:57 PM
Anyone?
Old 05-10-2011, 04:58 PM
BigBadWhitey's Avatar
Oil temp, Pressure, and maybe a trans temp gauge?
Old 05-10-2011, 04:59 PM
Why all oil related gauges?
Old 05-10-2011, 05:21 PM
riceburnerZ28's Avatar
It depends on what you need to keep an eye on...like forced induction & nitrous guys usually will have gauges like boost,fuel pressure, a/f wideband, nitrous pressure gauges. I only have oil temp, vacuum, and cylinder head temp gauges.
Old 05-10-2011, 05:33 PM
killerz97's Avatar
Coolant temp, trans temp, and oil pressure.
Old 05-10-2011, 06:37 PM
I'm thinking oil pressure, wideband, and one more and it's not forced induction
Old 05-10-2011, 06:46 PM
forgedlt4's Avatar
wideband
oil pressure
if AUTO..... trans temp
if M6.... vacuum
but YOU should know what gauges you will need.
Old 05-10-2011, 06:57 PM
This might be a dumbass question but what does the vacuum measure?
Old 05-10-2011, 07:07 PM
forgedlt4's Avatar
engine vacuum. basically, its how hard your engine in pulling on the air behind your throttle plate.
that vacuum runs a lot of you accessories (like power brakes)
a vacuum gauge can also tell you when something is wrong.
Old 05-10-2011, 07:08 PM
What kind of things foes it tell you is wrong
Old 05-10-2011, 07:14 PM
forgedlt4's Avatar
well, if your vaccum gauge is reading "off" or if it is boucing around it can be alot of things.
loose fitting, intake leak, collapsed lifter, bent valve, etc.
really, it just helps you narrow things down in the event something happens
Old 05-10-2011, 07:16 PM
The vacuum gauge can help diagnose several engine problems like intake/vacuum leaks, burned or sticking valves,worn valve guides, bad rings, weak valve springs, possible clogged exhaust system and more.
Old 05-10-2011, 07:40 PM
What will it do it something is wrong?
Old 05-10-2011, 08:03 PM
forgedlt4's Avatar
read at a different vacuum level (from normal), or bounce around.
Old 05-10-2011, 08:16 PM
What should the gauge read when it is at the right amount of vaccuun
Old 05-10-2011, 08:17 PM
What should the gauge read when it is at the right amount of vaccuum
Old 05-11-2011, 06:32 AM
pillarpod's Avatar
around 20
Old 05-11-2011, 07:23 AM
RamAir95TA's Avatar
Depends on a ton of things.
Have you tried a search? And I don't mean on this forum, but a Google search? These are some pretty basic questions you can probably have answered quickly and easily.
Old 05-11-2011, 08:16 AM
quik95lt1's Avatar
personally id run water temp, oil pressure and either a fuel press gauge or a WB02 gauge like the autometer ultralite.......
Quick Reply: Gauges
