water leak
Old 06-12-2011, 06:21 PM
Lawhead's Avatar
Default water leak
Putting water in the car today and did the whole bleeding procedure but with the EWP is it any different???? it stays below 210 but just leaks water when it gets some what up to temp and no idea where from all the hoses look good everything seems to be good car runs good and like said won't go over 210
Im stumped :/
Old 06-12-2011, 06:22 PM
gregrob's Avatar
Gotta find the leak dude.
Old 06-12-2011, 06:25 PM
1996firebirdformula's Avatar
Could be seal around the waterpump. Mine would heat up then it would just pour coolant straight down. Replaced Pump and Seals Fixed It for $85.
Cold Start in 3-5mins would start leaking.
Old 06-12-2011, 06:26 PM
Lawhead's Avatar
Every where I look is dry the old radiator that had a leak was replaced now its leaking from some where else hoses are all on there ive triple check I'll go at it with a clear head tomorrow. Car sounds great doesn't miss a lick its a great running set up from what it idles in the driveway.
Old 06-12-2011, 06:28 PM
stevo9389's Avatar
get the tool that pressurizes the coolant system with the car off. you will find the leak quickly. some common places are the back of the heads and the seal you made when mounting the EWP to the housing.
Old 06-12-2011, 06:29 PM
Start it up and get under there and watch where it starts leaking from.
I did have leaking problem with the coolant crossover line that goes into back of head after replacing manifold gasket.
Old 06-12-2011, 06:51 PM
LSWHO's Avatar
That's far too easy. Just post online.
Old 06-12-2011, 07:18 PM
Lawhead's Avatar
its in the front on the passenger side almost like the cap but don't see nothing come out of the cap got dark on me so going to go out there with a clear head tomorrow and see where it gets me just with it being almost done I keep trying to rush things which isn't a good idea
Old 06-12-2011, 11:51 PM
IronOutlaw's Avatar
I bet you bumped your low coolant sensor with the battery.
Old 06-13-2011, 07:42 AM
Village Troll
SS RRR's Avatar
What is the level of your reservoir? Does it too show it's low? If not then you may have an air leak rather than a coolant leak. What I mean is air may be entering the return line between the reservoir and radiator. I'm sure as you know when coolant gets hot it will enter the reservoir and as it cools, will return to the radiator. If air is introduced into the return line from the reservoir it will stop coolant from returning. When you pop the radiator cap the radiator will be low.
If you've replaced your radiator with an aftermarket one from the likes of Autozone or equiv. the hose ports and such may be smaller. I did this and had to put screw type hose clamps on many of the ports due to them leaking. Found the coolant return line port for the reservoir to be smaller and the clamp was not sealing the hose which introduced air into the system as described above.
As suggested, get a coolant pressure tester and test when engine is cool. Don't go over 18psi.
Just starting a car and looking for a leak doesn't always work, street prep king genius. Sometimes a leak can be in a place where the coolant hits a hot spot and evaporates before it can be seen.
Old 06-13-2011, 08:54 AM
Lawhead's Avatar
Water is deff coming out of the reservoir everything is fine till it gets close to 210 then it starts spewing out. I was thinking maybe pump hooked up backwards? but not sure if thats even possible last i checked black was always ground and thats how i have it hooked up now
Old 06-13-2011, 08:58 AM
Village Troll
SS RRR's Avatar
Spewing out where? The reservoir cap? If so, check to make sure the lines from the steam pipe and reservoir are not mixed up. The reservoir line should be on the top port just below the radiator cap and the steam pipe line below the reservoir port/line.
Old 06-13-2011, 09:35 AM
Lawhead's Avatar
Pretty sure thats what it was went out there changed them around and tighted all the clamps again and no water and the temp wont get over 180!!! should be going tonight!!!
Never thought this day would come but
Thanks SS RRR
Quick Reply: water leak
