I just cant win.
Old 08-28-2011, 12:21 PM
lethal bird's Avatar
Default I just cant win.
So i spent last night and today putting my new coil overs on and this morning getting every finished up and now the car wont start. I have absolutely no idea what it is. The car was running fine before i put everything on. Any suggestions where to start looking?
Old 08-28-2011, 12:31 PM
carlos64030's Avatar
Do the basic stuff first, like checking for spark, fuel pressure and fuses.
Old 08-28-2011, 12:33 PM
Also, turn your key on without cranking the motor and make sure you can hear the hum from the fuel pump.
Camaro350Z28's Avatar
wont start? it turning over? check fuel pressure like stated then if thats good lean on spark
Old 08-28-2011, 12:38 PM
Ill have to check pressure later this week because i dont have a guage, and i hear the fuel pump priming so i dont think its the pump.
Old 08-28-2011, 12:40 PM
Although i can hear a sucking hiss noise coming from under the hood every 2 or 3 seconds while i was trying to crank it that i have never noticed before.
Old 08-28-2011, 01:21 PM
The hissing almost sounds like its coming from behind the intake from what i can tell.
Old 08-28-2011, 01:22 PM
96TransAmboosted's Avatar
You need to be more specific on what the car is doing. Is it turning over like it should? Ifyou don't have a spark tester use an old plug or screw driver.to verify you have spark. Without a fuel test gauge its gointo be hard to tell if you have proper fuel pressure.
Someone is going to say must be the opti since you swapped the shocks....lol a joke of course. Diag is needed.
Old 08-28-2011, 01:28 PM
Yea im not so worried about the opti its brand new not even 1000 miles yet, the car was running fine before i started putting the shocks on. I will be able to check fuel in the next few days (going out of town today), and i dont have any one to help check for spark now so that will have to wait too. But its turning over like normal EXCEPT for the hiss every 3 seconds, it just wont start.
Old 08-28-2011, 01:57 PM
The opti comment was a joke , everyone is so quick to blame the opti. Need proper diag before you can blame anything. But if the opti is only 1000 miles old then there could be someting there. If you were close I would help you
Old 08-28-2011, 02:01 PM
blackmagicturbo's Avatar
car low on gas ? jacking it up on low gas could of emptied the sump
Old 08-28-2011, 02:04 PM
Yes it was very low on gas went and got a gallon jug and filled it up before i even tried to crank it.
Old 08-28-2011, 02:16 PM
Just went out and pull a plug wire and stuck a screw drive in the connector and tryed to arch it off the headers and got nothing.
Old 08-28-2011, 04:06 PM
Is there a way to check the coil for spark? Cause i find it hard to believe that the opti is dead again. It was running perfectly
Old 08-28-2011, 04:07 PM
Is there a way to check the coil for spark? Cause i find it hard to believe that the opti is dead again. It was running perfectly before i started putting the shocks on.
Old 08-28-2011, 05:18 PM
Are the grounds on the passanger side block tight?
Pull the wire off the opti and test the coil there. Be careful cause it will bit you.
Old 08-28-2011, 05:26 PM
Ill check that as soon as i get back on tuesday.
Old 08-28-2011, 07:02 PM
the_merv's Avatar
What did you disconnect to put the coil overs on?
Old 08-28-2011, 07:48 PM
The only thing removed was the master and the shocks themselves. But the doesnt explain why im not getting spark. My uncle tried to tell me maybe i sweat on the coil or the icm and shorted it out some how? Or maybe i rested my arm on something pulled a connector aloose.
Old 08-29-2011, 01:29 AM
the_merv's Avatar
I'd just check everything over..
Quick Reply: I just cant win.
