Valve geometry correct? (pic)
Old 08-31-2011, 12:41 PM
Rob94hawk's Avatar
Default Valve geometry correct? (pic)
This is cylinder #1 intake valve and the mark is leaning toward the exhaust valve. I remember reading that as long as it's toward the exhaust it's ok. Correct? (Note that this is with the test pushrod @ 7.2", I never took pics of the correct rod length and they all made this mark.) Thanx
Old 08-31-2011, 01:07 PM
wrd1972's Avatar
It looks decent. I will speculate that if you put in a 7.150" PR, the pattern will move to the center but the sweep will get larger. More sweep means more parasitic power loss and IMO has more negative impact than the patter being a tad off center as shown in the pic. You definitely dont want the pattern going much further to the exhaust side than what is in the pic.
wrd1972's Avatar
It looks decent. I will speculate that if you put in a 7.150" PR, the pattern will move to the center but the sweep will get larger. More sweep means more parasitic power loss and IMO has more negative impact than the patter being a tad off center as shown in the pic. You definitely dont want the pattern going much further to the exhaust side than what is in the pic. BTW it is near impossible to have very minimal sweep and the perfect centered pattern so avoid looking for that treasure.
Old 08-31-2011, 01:34 PM
Rob94hawk's Avatar
So your thinking is to stay with the 7.2"? Haven't ordered the PR's yet so I've got time to think things through.
Old 08-31-2011, 02:16 PM
spudnick3119's Avatar
If you have a pushrod checker tool, then test one with 7.15". Are you using LS7 lifters? They tend to require a slightly shorter pushrod. I ended up with 7.15" pushrods with stock, untouched heads (not that you should go by that, always measure).
Old 08-31-2011, 02:37 PM
Rob94hawk's Avatar
I have new LS7 lifters and with the PR checker the mark was centered but off to the exhaust side.
Interesting that your PR length is the same as mine. My heads are milled .012" and the head gasket is .026". What gasket and rockers did you use?
Old 08-31-2011, 02:39 PM
RamAir95TA's Avatar
Are your guideplates centered on the rocker studs?
Old 08-31-2011, 02:41 PM
Rob94hawk's Avatar
Yeah. That was a PITA. I eyeballed them, hand tightened, then incremently torqued them down.
Old 08-31-2011, 04:06 PM
Big Al's Avatar
I ended up with 7.1's. This is something you need to check yourself. Multiple valve jobs or aftermarket valves will change it.
Al 95 Z28 w/ Manley Pro-Flows
Old 08-31-2011, 06:16 PM
gregrob's Avatar
That is an internet myth. The cup height is exactly the same...
If you required a shorter pushrod it was not because of that.
Old 08-31-2011, 06:29 PM
There were pics posted a while ago on cz28.com showing the cup height difference between stock LT1 and LS7 lifters, maybe they changed... that's why I said to measure and be sure.
Old 08-31-2011, 07:04 PM
wrd1972's Avatar
I measured the two side by side with a dial indicator a while ago. The cup in the LS7 lifter sits about .050" deeper in the lifter body. IMO, they did this to the cup end to provide more metal above the retainer clip to for a bit more strength.
Regardless, this slight difference will do little to affect PR length.
Old 08-31-2011, 07:45 PM
Rob94hawk's Avatar
Talked to a Comp cams rep. He wants me to do it again.
Old 08-31-2011, 11:20 PM
the_merv's Avatar
.050" of an inch is a decent amount on the Pushrod geometry..that's a .050" longer Pushrod needed to compensate for it.
My question is what exactly was the Lifter you had?
I ask cause my LS7's were shallower than a stock LS1 Lifter..and I have a stock set of Lifters here in my garage that came out of an LS1. They arent stock LS1 Lifters..they look identical to LS7 Lifters, but the cup is the same as a LS1 Lifter.
Here is some info I found to help out FWIW..
LS7 on the left, stock on the right.
http://www.camaroz28.com/forums/showthread.php?t=690137
Old 08-31-2011, 11:55 PM
the_merv's Avatar
Here's another one to help..
https://ls1tech.com/forums/15011466-post7.html
Old 09-01-2011, 12:49 AM
BALLSS's Avatar
as suggested I would use the adj PR tool at 7.150 and 7.100 and pick the one with best pattern.
looks like you could go slightly shorter on PR
Old 09-01-2011, 06:42 AM
wrd1972's Avatar
I had my original 95 LT1 lifters and a newer set of LS7's bought in 2007 IIRC. Looking at your pic, that metal lip above the clip that captures the clip, on the LT1 lifter that lip was thinner and on the LS7 lifter it was noticably thicker I assume for additional strength. I also dismantled both and cam to the conclusion that the guts of both were identical. From what I saw, the cups appeared to be the same and the depth at which the PR sat, also appeared to be the same. It was the depth the cup sat in the body (bore), due to the moving of the clip, that appeared different to me.
Old 09-01-2011, 07:40 AM
Village Troll
SS RRR's Avatar
Absolutely. This was the problem with the Comp R lifter. The later versions had a paper thin retainer clip. Those with unstable valve trains would toss a lifter, the plunger would then hammer on the clip, the clip would effortlessly break and then you would read about the bitching of the lifter being bad. That clip serves no function while the lifter is in the engine and the valvetrain is properly adjusted.
Old 09-01-2011, 09:05 AM
wrd1972's Avatar
Old 09-01-2011, 01:38 PM
the_merv's Avatar
Agreed. I guess the height difference has to be accounted for with the Preload.
Quick Reply: Valve geometry correct? (pic)
