megasquirt
What are you looking to accomplish? The existing computer is one of the cheapest and easiest there is to work with, hell there is FREE scanning and tuning software for it.
The only real limits it has is about a 7000rpm hard rev limit, beyond that there are people making it run massive injectors, and a 2-BAR map.
really? im having alot of trouble with getting it started i may have sent 12v straight to the pcm now nothing is working "no lights no nothing" i checked every fuse every breaker so i think i messed it up pretty good so i ether need a new pcm. but i was going to do a rear mount turbo and i was told the stock computer cant deal with boost very well
About the Megasquirt. There is a big following with the MOPAR guys. If you want some links let me know. Their webpage, http://www.megasquirt.info/ has lots of information.
I have a Ford with a Electromotive system. Believe me it's a lot easier working with something designed to be easy to tweak. Holley just came out with a system too.
http://www.holley.com/types/Dominator_EFI_-_ECU.asp
http://www.holley.com/HolleyNews/article.asp?ID=206
Al 95 Z28
Al 95 Z28
I haven't tried it because I bought Tunercat and Datamaster long ago but I do believe TunerPro has a datalogger with it.
LONG before that was Freescan which is a bit flakey but still GREAT for the price.
Even if you pay full retail for Tunercat, Datamaster and a cable you are still in under $250 easily.
GM stuff usually has a lot more aftermarket support than Ford and WAY WAY more than Mopar, I would not look that way for ideas. Other cars have to resort to halfassed things like MAF translators and such, on one of these though that would be more expensive and less productive than tweaking the pcm to do what you want with the properly measured airflow instead of lying to the pcm about airflow the way a "translator" does.
Resident Racing Jerk
megasquirt works good on my car. i bought as a kit and assembled myself. think it was $300 or something like that? cant remember now.
-no rpm limit
-low impedance injectors no problem
-tuning on the fly
-ditched my opti for a crank trigger and dizzy
-no rpm limit
-tuning on the fly
Thats great and everything but some people are stuck with a 93 ECU and dont have flash capability or the great selection of tuning software.
Although, some argue that the 93 stuff is actually better if equipped some of the cool stuff over at moates.net but ive never worked with the free tuning software... Im worried the interface will be complicated and not very user friendly...which is usually what you get with "free."
