timing chain
Old 10-05-2011, 09:06 PM
LigHtEmUp01's Avatar
Default timing chain
ive used cloyes timing chains and gears and theyre all loose! the best combo i had was original big gear with new little gear and cloyes chain from oreilly, we tried 4 chains and all where loose. whats a good chain to use???
Old 10-05-2011, 09:23 PM
ebeard's Avatar
LT1 chains tend to have a little bit of slack. I remember being worried the first time i put one on. Mixing parts (chain, big, little gear) from different sets doesn't sound like a great idea. how much can you move the chain from side to side?
Old 10-05-2011, 09:26 PM
prob half an inch not exactly sure this was a while ago when we put it together i know we got it good enough to run with but its apart again and i wanna get it right but i know ive pulled 150xxx mile motors apart with better tension than what i had
Old 10-05-2011, 09:39 PM
ebeard's Avatar
Maybe check this out. https://ls1tech.com/forums/lt1-lt4-m...slack-o-k.html
I would measure what you have. If your not satisfied, I would go with a GM chain. But that's just me ha.
Old 10-06-2011, 08:13 AM
95sscamaro's Avatar
Originally Posted by guppymech
This post recommends using a oversize Cloyes crank sprocket to reduce the normal LT1 timing chain slack.
https://ls1tech.com/forums/lt1-lt4-m...ing-chain.html
Note: Part numbers on 2nd page.
X2 on the oversize crank gear, i had the same problem you have and this fixed it
Old 10-08-2011, 05:41 PM
i have a pin driven opti and that post said to just replace cam gear but i have already done that and didnt work. cant i just buy the oversize crank gear with stock chain/cam gear??
Quick Reply: timing chain
