HELP!!!! Loss of Power and Weird Whistling Sound
I need some help, bad. I was at the street races tonight. Car was running fine. Then I raced my buddies WS6. After the race my car was running a little warmer than I would like. Like 240ish. So I cut it off for a little while. Turned it back on and there was this weird *** whistiling sound. Very high pitch. Like a turbo at like 40psi. The overheating stopped. But this whistle sound was scaring me. The cops showed up and busted the place. I hauled *** out of there. My car was running just fine. Normal temps, oil pressure, etc. Even kept up with a mach 1 on the way out. Then all of the sudden, my power just started dropping off. Temps were still fine. Oil pressure still good. No missing or sputtering or anything. It was running fine, but just no power. The whistling sound still there. The power loss got to the point where I couldnt even keep up with my buddies V6 camaro. Then it got so bad that my other friends z71 totally obliterated me from a stop light. The car was still running just fine. Just this odd high pitched whine and extreme power loss. I pulled in at the next gas station. It sat there for like 10-15 minutes while we all tried to figure out wtf was wrong with it. I started it back up and bam, my power is back. Not all of it, but its got enough to actually be considered a sports car. I drove it home just fine, whistling the whole way. Now I'm just so ******* confused. I have no idea wtf it could be. I've went through everything in my head. I assume the whistling and powerloss are related, but maybe I'm just so god damned unlucky that they are two separate problems. IDK. All the things that come to mind don't make any sense. Some one please help me.
Ever thought that it popped a head gasket? 240 is pretty hot for aluminum head. Loss of power maybe due to water or oil getting into places it should not and that's why the loss of performance. Its just a guess tho. You need to start diagnosis to figure out why and where.
Vacuum leak is pretty much what I think I'm stuck with. I'm just not sure if it could cause a drastic power loss like the one I experienced last night. It was a good 100hp loss. The rpm's in 1st gear were climbing like I was in 4th gear at 15 mph. Very slow rpm climb. I'm at a loss here. I'm about to go disconnect every vacuum line and reconnect. Maybe I can find a problem. IDK. I'm about to go ape **** on this problem. I have no idea was going on with this bitch. Someone sugested Opti problems, but that doesnt explain over heating and whistling.
Ok the whistling is solved. No major problem there. Over heating was because my fans were magically unplugged somehow. Loss of power I'm giving that to optispark. My car has no power after 3000 rpms and won't go past 135 mph any more. Sounds right to me. Any body got a better idea?
It was odd that all of this happended within 30 minutes of each other. Overheating, whistling, and power loss. Turns out they were unrelated. But to answer your question, where the bell housing and motor meet there is some kind of thin peice of metal that I suppose acts as a dust sheild or something for the flywheel. Anyways, it was loose frome the bell housing and the flywheel was pushing air through a small crack. It sounded like a 4 liter whipple super charger hitting 20 psi. It was stupid loud. Anyways, thats fixed. Just gonna buy a Chandler opti and put that bitch on there. I'm gonna replace plugs and wires while I'm at it. I should be good in about 400 bucks. I hope.
I've heard nothing but good of chandler optis. Have you ever owned one? Id like input from folks who have actually used these in the past. 100 bucks does seem a little too good to be true...
don't see a problem yet...
Chandler opti sparks are crap from my experience. I put a brand new one on and it was junk right off the bat luckily I had a stock cap and rotor and that fixed the problem but as for the warranty that's crap it was impossible to get ahold of them. All I got was a email of the address to send it to and asked for a phone number probably 4 times and kept getting the same email. Complete waist of money
