Did some dyno testing had some good results NA
Figured id toss up a post about my latest attempt at finding a few more hp.....put the car on my friends dynojet for the week, Precision Dyno in Cranston, RI. Baseline test showed 553rwhp at that point i put some fuel in it and a hair more timing which netted, 560, then after a few more shots i wound up at 568rwhp......graph below
![](http://i919.photobucket.com/albums/ad38/quik95lt1/IMAG0149_zps22b9aa29.jpg)
from there i wanted to check cylinder balance so i put a WB02 in each header tube did 4 at a time.......
![](http://i919.photobucket.com/albums/ad38/quik95lt1/IMAG0151_zpsadd7c4e6.jpg)
![](http://i919.photobucket.com/albums/ad38/quik95lt1/IMAG0147_zps9838477c.jpg)
at the end of the test, it turns out paying the extra coin for flow matched injectors is worth it, as well as taking time on the cam and airflow in the motor, even with the single plane intake with runner length differences i saw no more than .24:1 AFR difference from one cylinder to the next i got them to within about .2 it made no noticeable difference.........
all in all i think it went quite well I picked up 15rwhp and 13ft/lbs peak but about 18ftlbs up in the high rpm range....through 29" slicks, an unlocked 5200 stall th350 and 4.56's in a dana 60 I think those are awesome numbers for a car that i had already spent time tuning before and was already running great.....it ran 9.77@138.xx going easy on the launch with the old tune....i think its got some impressive numbers in it dialed in especially later this year in cooler weather....
![Secret](https://ls1tech.com/forums/images/smilies3/secret2.gif)
Looking good man, I'm hoping on having mine on the engine dyno sometime this year. Gotta get in touch with lemons for some custom headers ($$$) then decide what computer I go with.
yup same heads/cam as last year.....just did some tweaking
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
