rocker arm adjustment
im doing it the engine running way.
they all seem to be clicking, how do you guys differentiate between which rocker arms are clicking and which arent
Easy, put your finger on the rocker arm. You'll feel it. Tighten the ones that are clicking until they shut up and then do them one at a time. Did you decide how much past zero lash you're going to go?
Al 95 Z28
Al 95 Z28
I never liked doing it that way. I always use the comp cams method and it always works great. Use steps 7-8
http://www.compcams.com/Instructions/Files/151.pdf
went ahead and did the engine running method.
it was pretty easy, just was a bit intimidating at first. especially since it was smoking like a **** from the oil dripping onto the headers.
Beer case cardboard cut into strips and shoved into the head in a manor that allows it to drain back AND keeps the oil off the exhaust .. Works well ,Unless you want a fire and or a stupid smoky mess.
On a side note worthy of mentioning, a automotive stethoscope is a good CHEAP tool to use when doing this to single out one rocker from all the others..
So simple it is stupid
ya they did! at first i was confusing the sound of them moving with clicking. but i got em all good now
thanks for that advice i didnt know that to be honest. ill do both of those next time
You should ALWAYS use a splatter shield when tightening in this method!
I've done it both ways and I prefer the engine running method unless the car has pretty loud exhaust. I even made a shroud out of an old SBC valve cover with the middle cut out. If your having a hard time hearing it you could try a mechanics stethoscope or a screw driver. I have only readjusted mine once since I did the LS7 lifter swap over a year ago.
