bmr a/c block off plate...
Old 12-28-2011, 06:15 PM
lt1whatwhat?'s Avatar
Default bmr a/c block off plate...
so i just got this wonderfull plate an had it powder coated. now i was wondering the best way to install it. is there a spcial way i should take everything out so i dont mess anything up. OR should i just start going ham an rip every thing out with no regardes for what im doing. some one let me know what you would do.
thanks....
Old 12-28-2011, 06:18 PM
lt1slowz28's Avatar
be careful with stuff you may want to keep, otherwise take care around the pcm and under the dash.
Old 12-28-2011, 06:26 PM
well im going to relocate the pcm to under the dash along withevery outher wire in the bay. but idk what i should keep???
Old 12-28-2011, 07:33 PM
o0o an does anyone want a block off plate the sent me two an i only need one haha. just let me know.
Old 12-28-2011, 08:37 PM
93v8clone's Avatar
What plate ? Does it cover the hole if ya yank a.c out ?
Old 12-28-2011, 08:38 PM
lt1slowz28's Avatar
ill take it
Old 12-29-2011, 08:22 AM
bufmatmuslepants's Avatar
It's for heater box removal. Get a sledge, a prybar, and I believe 8mm socket on a 12 inch extention. Loop the heater hose, scrape the rubber mat and glue off.
Old 12-29-2011, 10:34 AM
MEAN LT1's Avatar
I did it the hard way and took it out from inside the car. A total PIA and next time I would have just cut it out from the engine bay. However the cover goes inside and I just used some of the screws that was used for the hvac to secure the plate back on.
Old 12-29-2011, 11:36 AM
96TransAmboosted's Avatar
I removed the dash to install my plate, took 30 min to pull the dash. I had the dash angled on the drive seat for room. I used bolts I bought from the local hardware store. I also used a 1 in double sided weatherstrip to seal it in place. Worked great. Just be careful of the center bracket on the dash, very easy to bend it out of wack.
Old 12-29-2011, 03:39 PM
ok it looks like ill be doing it from the inside. just to make shure i dont get rid of anyhing i need. thanks for the advice.
Old 01-18-2012, 03:01 PM
Wicked94z28's Avatar
still have that heater/ac plate?? if so ill buy it from you!! lmk!!
Quick Reply: bmr a/c block off plate...
