Need help choosing clutch
My clutch just went out and instead of stock clutch I want to get a performance one and juz need help choosing a good one any suggestions?? Thanks for the help
'Nother vote for Spec. You obviously have a lot of options/recommendations. Just be sure to get one rated for your desired horsepower levels -- the stronger the clutch, generally the less streetable it will behave.
Regardless, you're probably going to want to resurface your stock flywheel if you intend to reuse it. I take mine to a local CarQuest machine shop, and they removed about 0.020" last time. To keep things properly located and prevent disengagement issues, you can buy a Gen-II SBC flywheel shim of the same thickness as the material they remove, which are available at places like Summit Racing (or perhaps your local machine shop can sell you one).
