Are these injectors large enough?
Old 02-17-2012, 08:48 AM
fuzzyjk's Avatar
Default Are these injectors large enough?
I have 37 pound Delphi injectors, thought they were 30s (bonus!). They were in a 96 and I would be putting them in my 1994. My current mods are..... mild head/cam/RR car with bolt ons and a Vortech running 6lbs all on a stock cubed block.
Will they work on the low boost?
Thx
Old 02-17-2012, 09:15 AM
draggin97s10's Avatar
Thx
probably at higher then stock FP. But im not sure, i dont know alot about FI
Old 02-17-2012, 09:34 AM
05HD's Avatar
Those injectors should be big enough for around 450 hp (crank) with a .6 BSFC, ASSuming the rated flow is at 43.5 psi and that is the pressure you are running. I used 90% IDC max on the RC fuel injection calculator to arrive at that conclusion.
Old 02-17-2012, 10:03 AM
pillarpod's Avatar
do you know how much power you make now?
Old 02-17-2012, 10:44 AM
fuzzyjk's Avatar
No idea on the current power. I am guessing around 300 at the wheel and the supercharger will add about 100 whp more. I would say it would be around 500 at the crank. So.....at 43.5psi, can I add a booster pump to bring up the pressure or am I all "wet"?
Old 02-17-2012, 11:50 AM
warriorcustoms's Avatar
To bump up pressure on an LT1 get an afpr Holley makes a rebuildable one good to 65psi & as low as like 35psi Got one on my motor
Old 02-17-2012, 12:10 PM
stuart4185's Avatar
it should be close, if you run out of fuel top end, you can just limit your rpm until you get larger injectors.
Old 02-17-2012, 04:21 PM
fuzzyjk's Avatar
Guess I will install......thx.
Quick Reply: Are these injectors large enough?
