2 step for 94 lt1
Old 02-19-2012, 06:34 PM
b00geyman's Avatar
Default 2 step for 94 lt1
So I did a "search" here and Google and really didn't find the info i need. I want to know if it is possible to install a 2 step system in the 94 camaro's and if it is worth it. I have seen some sick **** with the 2 step
Old 02-19-2012, 07:31 PM
stuart4185's Avatar
its an add on box for an MSD system, but unless your running a turbo, it wont make you faster
Old 02-19-2012, 07:53 PM
TSAEB's Avatar
Not sure if it's the two step but I would think to be able and press the gas peddle pushed completely down and keep rpm at your desired limit would help be more consistent. Not saying this is true , I never ran a 2 step just thinking it.
Old 02-19-2012, 08:18 PM
zraffz's Avatar
Absolutely.
MSD 6AL2 is what you want. It has two stages of rev limiters, one for burnouts/launches and the other for overall rev control.
I plan on running the programmable 6AL2, which has 3 stages. One for burnout, one for launching on the trans brake and one for overall protection. It also pulls timing instantly when the nitrous is turned on.
Old 02-19-2012, 08:43 PM
b00geyman's Avatar
is this for manual only? and turbo cars only?
Old 02-19-2012, 08:46 PM
zraffz's Avatar
No it would work for anything from automatic hondas to manual vipers.
Their is no reason not to have a multiple stag rev limiter. You can't get more consistent.
Old 02-19-2012, 08:52 PM
Rocker665's Avatar
My buddy has a the MSD 6AL2 on his 78 TA with a TH350 you can put it on any car your heart desires, haha ill be getting one soon for my 93
Old 02-19-2012, 09:05 PM
96LT1355Z28's Avatar
I have a 2 step, it doesn't make the car faster but it does make it much easier to be consistent and easier when dialing in suspension. You will need a 6AL box, Digital 6, or the new 6AL2. It's activated by a momentary switch or button and when activated changes the ignition rpm limit. When power is supplied it's activated when it's not the normal rpm rev limit is used. I have a momentary button on my shifter that activated the line lock and 2 step. The + for the 2 step from the button has an inline toggle switch. This is so I can turn it off for the burnout and then on for the staging bulbs. My process goes like this: into water box 2 step toggle off, set brake, push button and do burnout, let off button and roll out of the box, 2 step toggle on and into t he pre stage beam, lightly set brakes and push button, use gas and clutch to bump into stage beam, once opponent has staged gas to the floor, 2 step holds rpm to whatever I have it set at, simultaneously release button and clutch to launch!
Old 02-19-2012, 10:51 PM
b00geyman's Avatar
pretty sick but if don't make the car faster whats the point. less burnout i guess to grip better
Old 02-19-2012, 11:09 PM
ZFreie's Avatar
What he said
Old 02-19-2012, 11:14 PM
1badzee's Avatar
Strongly considering hooking up the 2-step on my Digital 6. Hoping it will help solve some consistency issues while launching.
Old 02-19-2012, 11:18 PM
You would be very surprised how much easier it is to launch and the consistency your able to obtain.
Old 02-20-2012, 11:48 PM
gregrob's Avatar
Mallory 685 has a 2 step option built in as well...
Heres a vid of it in my car. Helped manual launches on the street a lot....
http://www.youtube.com/watch?v=2VWlM2-jD88
Yes I know its dark. I'm in right lane, boosted 72 is in left lane. You can hear the 2 step...
Heres another:
http://www.youtube.com/watch?v=Xp6NhmzGp5A
Old 02-21-2012, 06:21 AM
BIGCAT7274's Avatar
there's several ways you can use them. they are a big help when it come to getting of the line consistently.
Old 02-21-2012, 07:22 AM
Jpack's Avatar
Mallory 685 in mine.
Old 02-21-2012, 08:40 AM
whytryz28's Avatar
[youtube]W2Rmjlysp98[/youtube]
jk I want to add one to mine actually.
Old 02-21-2012, 02:54 PM
b00geyman's Avatar
That thing must MOVE!!!
Old 02-21-2012, 10:18 PM
b00geyman's Avatar
does the msd 6al-2 replace the stock ignition system?
Old 02-21-2012, 10:40 PM
fex77k's Avatar
No it just controls the coil and lets you set the retard in the digital 6.
Old 02-21-2012, 11:29 PM
SoxXpupPeT's Avatar
I have a 6al-2 box and lt1 harness. pm me if interested.
Quick Reply: 2 step for 94 lt1
